I can see why Drew likes this pipe so much. I finally got mine done today with the Andrews cam and the Heritage D&D on along with a Dyno Tune. 80hp and 90tq. Not bad for just a mild cam considering it was 75 and 83 before.
I luv how the low and mid range work now. 6th gear is so much more usable.
And it growls and angry growl. Luv the pipe. Very happy with the results.
Drew, question for you. Since your running a bagger tail. I guess I know that the fat cat works with your road king bags and the bagger tail. Do you think Hard bags w/the bagger tail will work also with the fatcat? I am thinking it shouldn't be a problem.
No problem at all. I am thinking of getting hard bags or extended hard bags. You can run the bagger tail for "low mount exhausts" too as the bags sit a bit lower.
