Lowering rear
Old Mar 13, 2011 | 03:51 PM
zworld's Avatar
zworld
Default Lowering rear
Hi guys, I want to pick your brains. I want to do the rear shock lowering bolts on my 07 fxst, she leans over pretty far rite now, will I need to do something with the kickstand if I lower the rear? I just want to get the inexpensive shock kit extensions.
Old Mar 13, 2011 | 04:14 PM
kozy22's Avatar
kozy22
You don't need to but it would be better to. Your bike will just be more upright than it is now
Old Mar 13, 2011 | 08:57 PM
tmitchellof PG's Avatar
tmitchellof PG
It shouldn't make that much difference, if you just lower it an inch or so. That's approximately how far the rear of the Deluxe, Fat Boy LO and my SE Fat Boy is lowered and they come with the same jiffy stand as the other Softail models. My SE doesn't lean over as much when it's on the jiffy stand then the regular Fat Boy, but I've never had a problem.
Old Mar 13, 2011 | 09:44 PM
klf33's Avatar
klf33
Depends on your pipe type, usually the right side is the limiting side, yes it will touch faster, I found that lowering the front at the same time gave me better clearance than just the rear.
I have the rear down 1.5" and the front 2"
Old Mar 13, 2011 | 10:12 PM
WARG's Avatar
WARG
No, lowering the rear should not be an issue. I have air ride and can slam it without issue. Now I lowered the front 2", and added the shorter stand.
Old Mar 13, 2011 | 11:52 PM
kiwideuce's Avatar
kiwideuce
pretty easy to lower! here is how you do it!!
https://www.hdforums.com/forum/softa...nty-bucks.html
Old Mar 14, 2011 | 03:24 AM
RICHIEMACK's Avatar
RICHIEMACK
Once you lower the front ,you need the shorter k stand
Glide2001
May 9, 2014 07:54 AM
RoadPirate
May 3, 2011 10:06 PM
bbs15
May 30, 2010 09:01 AM
toddlaroche
Mar 14, 2010 08:30 PM
per sweden
Mar 3, 2010 02:46 PM
