Changing Fork Oil
Old May 18, 2011 | 08:11 AM
PPBART's Avatar
PPBART
Default Changing Fork Oil
Planning to change fork oil on my '05 FLSTN. Never done this before, but service manual seems pretty simple -- any "gotchas" that I need to be careful about?
Old May 18, 2011 | 08:20 AM
dFREDb's Avatar
dFREDb
Have plenty of newspaper around to lay the springs on while you drain the oil. Also have a way to hang each fork upside down to drain thoroughly. You can use a sliding caliper to fill them to the correct level. Other than being a little messy and time consuming, very easy. Good luck!
Old May 18, 2011 | 09:03 AM
Mike NY's Avatar
Mike NY
You have to remove the whole fork from the bike? Why can't you just remove the drain bolt?
Mike
NY
Old May 18, 2011 | 09:32 AM
KumaRide's Avatar
KumaRide
Correct, just remove drain bolt. Its easy to do. I used Maxima 15w. It stiffened the front end a little and reduced front end diving when braking. Better road feel also.
Old May 18, 2011 | 09:52 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
Cool Forks
I WAS TOLD, AND BOOK SAID TO ALSO, REPLACE ALL O RINGS, GASKETS, WASHERS AND DRAIN PLUGS. SEEMS LIKE ALL H-D PARTS LIKE THAT NEED REPLACING EACH TIME.?? METAL PLUGS STRECH AND LIKELY TO LEAK. STRESS.
Old May 18, 2011 | 09:56 AM
Sgt_Jim's Avatar
Sgt_Jim
Mike
NY
only if you disassemble them, which you don't need to do if you're just changing the oil in them.
Old May 18, 2011 | 09:58 AM
KumaRide's Avatar
KumaRide
You only need to change the two upper seals where you add the oil and both drain screws and washers. $20 total including oil - cheap The manual tells you what to change and the OP says he has a manual. If he has a fork seal leak then thats for another thread....
Old May 18, 2011 | 11:18 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Pull the drain plugs. Pull the caps. Pump the forks a bit to get all the excess out. Refill with appropriate amount of oil. Replace crush washer if you wish. The manual says to I believe.
Drew
Old May 18, 2011 | 11:40 AM
PPBART's Avatar
PPBART
No leaks, so I don't plan to disassemble forks.
Manual doesn't mention replacing the upper seals but that makes sense; however, is it necessary to replace the drain screws/washers? Certainly no objection to doing so if needed, just curious why. I'm making up my list of parts/supplies needed before heading into town.
Old May 18, 2011 | 12:49 PM
dFREDb's Avatar
dFREDb
Mike
NY
You are correct. Dynas require removal but not Softails. Sorry about that.
