Pos wont start!!!
Old May 20, 2011 | 08:35 PM
SMF's Avatar
SMF
Default Pos wont start!!!
Anyone have any ideas? 05 deluxe solenoid looks good no blown fuses all lights come on, no odometer, i can hear my fuel pump engage just no click or even turn ing engine wise i hit the swithc and nothing.
Old May 20, 2011 | 08:39 PM
Other Sheep's Avatar
Other Sheep
Might be a connection. Time to pull the seat, take the cables off the battery, clean then re-install.
Old May 20, 2011 | 09:00 PM
NCTURBOS's Avatar
NCTURBOS
So all electrical accessories work, correct? Just the starter doesn't engage to start the bike?
K.
Old May 20, 2011 | 09:02 PM
SMF's Avatar
SMF
No odometer either bro
Old May 20, 2011 | 09:03 PM
SMF's Avatar
SMF
Checked all connections, checked fuses and relays all aok
Old May 20, 2011 | 09:06 PM
HOG_0308's Avatar
HOG_0308
battery connections. happened to me last week. everything felt tight. i took the connections off, cleaned them and tightened everything down and worked fine....
Old May 20, 2011 | 09:09 PM
Other Sheep
Low battery voltage? The little lights and fuel pump don't take much to light up.
Old May 20, 2011 | 09:11 PM
Other Sheep
If you jump it put the neg clamp on a part of the frame. If you bump start it do it in second gear or even third. First will usually just lock up and not turn the motor.
Old May 20, 2011 | 09:19 PM
RANGER73's Avatar
RANGER73
My bikes older, but I had an intermittent no smart. Was the relay to the starter under the seat (it clicked but didn't mack contact, until I hit it with something). Replaced the starter relay and installed a starter push button.
Old May 20, 2011 | 09:24 PM
DaddyKnuck's Avatar
DaddyKnuck
Exactly what my Springer did last year. Rode into garage fine one night. Wouldn't start the next morning. Turned out to be the ign switch. I have a similar problem with my NT now. Except this time the bike starts and runs, but in both ign and acc positions. Also no speedo. I've already checked the switch with a known good one and that's not it. I'm in the process of looking to find a bad ground, or maybe a combination of problems. Your's sounds like the switch, however.
