I believe the 309-360 will work on 01 and up non TBW bikes, however check with Zippers. The only difference is 2010 and up bikes with cat convertors use small 12mm O2 sensors. If retaining original exhaust 18mm O2 bungs must be installed in the 09 OEM locations (about 4" from head). If installing aftermarket exhaust and removing OEM head pipes you can order 09 exhaust with 18mm O2 bungs. I installed bungs on my 03 and I love the auto tune. The bike runs like a scared rabbit. Here is a link for more info, once again contact Zippers to insure proper fitment.
Cheers! http://shop.thunder-max.com/shopexd.asp?id=134
This was copied from their website.
*ThunderMax® is not available for 2011-up Softail® models. Click Here to Pre-Order.
That is located on the page in the link below. http://www.thunder-max.com/Default.aspx
It not being available for the 2011 Softail Models yet has too do with the new electrical system they received, not O2 sensors.
