07 deluxe problem !!!
Old Jul 21, 2011 | 07:39 AM
furtrader's Avatar
furtrader
Question 07 deluxe problem !!!
Yesterday I finished up wiring in an audio system and had the tank off like, after I put it back together to go for a ride, it started very rough and like one cylinder was hitting. I had changed the fuel line and crossover line while it was off so I had to drain the tank.
I had zero problems before. I couldn't ever get to run regularly so I put it back in the garage.
It had a hard time starting, turning over but not firing, when it did it was rough with only the rear cylinder hitting with compression. I thought it was where there was air or no gas in the line to begin. I tried to let it run out but no luck.
Any ideas with this little amount of info???
Old Jul 21, 2011 | 09:13 AM
oldgeezer's Avatar
oldgeezer
Check the fault codes and see if it is throwing a code. You might possibly have knocked a spark plug wire loose so you might check those.
Old Jul 21, 2011 | 09:39 AM
furtrader's Avatar
furtrader
shew got it, was looking back over everything and saw a connector right behind the intake that had come undone. Not exactly sure what it is but some sort of sensor for the front cylinder, dis-assembled again hooked it back, now its back in business!
Old Jul 22, 2011 | 12:27 PM
cryan9's Avatar
cryan9
Make sure that both spark plug wires are connected nice and tight.
Old Jul 22, 2011 | 12:28 PM
cryan9's Avatar
cryan9
Disregard. I see you already fixed the problem.
Chris4
May 28, 2017 10:29 PM
Histicku77
Jun 24, 2013 04:54 PM
chordstrummer
Jan 18, 2011 06:02 AM
SURFOR Chop
Apr 15, 2009 10:03 PM
Sportsterd
13
Apr 19, 2008 01:27 PM
