Pulling Primary Cover
Old Oct 4, 2011 | 08:23 AM
jharanin's Avatar
jharanin
Default Pulling Primary Cover
I was wondering what you guys do about covering the primary if you're pulling the cover to get it powdercoated. it'll be about 2 weeks while I'm waiting to get the parts done and I want to make sure no moisture or dirt finds it's way in there...
Old Oct 4, 2011 | 09:19 AM
Tx_Outlaw's Avatar
Tx_Outlaw
Stuff rags in it. I'd be a lot more concerned about cylinders being open than the primary and most people just stuff those with rags. (Not sying you said anything about cylinders, but using as an example)
Old Oct 4, 2011 | 09:34 AM
Captain Itch's Avatar
Captain Itch
Sponsor
I would just throw a towel over it..But I would suggest that you change the screws out to allen heads while you have it off..
__________________
www.Captain-Itch.com
Old Oct 4, 2011 | 09:38 AM
2006FLST's Avatar
2006FLST
I always just crammed a trash bag over it all to cover it up. I would not worry too much about the primary. The big thing will be the mess it makes taking the cover off. I always take a trash bag (there is a theme here!) and wrap it around the frame really good to allow the left over fluid to run down the bag so I can catch it. It will be messy. If you have never pulled a cover make sure you pull the inspection cover off. Two of the bolts go into the inner cover holding the outer cover on. Good luck and it should look good.
Arnold63
Jul 11, 2018 11:06 AM
twoseas
Aug 7, 2017 09:56 PM
raptorgabe
Jul 25, 2015 02:59 PM
800screws
EVO
Jul 1, 2015 03:04 AM
wingnutt
Jan 9, 2008 01:40 PM
