Evo pipes onto 96 twin cam?
I "think" they have the same size head connections but the frame mountings may give you a problem because of the wider frame width at the rear.
You'll also need to add O2 bungs for the ECM unless you use eliminators and welding them on is not going to do much good to the chrome in the immediate area.
You'll have to add the sensor bung or bungs depending on your year,otherwise it will bolt up.Put them in on the back side of the heat shields and you won't ruin any chrome.Lots of part retailers sell the bungs for 8.00 each.Drill the holes yourself and if you can't weld any shop will more than likely do it for a little cash. A lot cheaper than buying a new set of pipes if you like the ones you have.
ettev
01-27-2008 03:31 PM
