Will Evo Headers fit a 96" Twin cam ?
Old Apr 1, 2013 | 07:33 PM
WhereduGo?'s Avatar
WhereduGo?
Default Will Evo Headers fit a 96" Twin cam ?
I have a set of Stainless headers that only connect to the cylinder heads they are older and made to fit a EVO style big twin, I was wondering if these will fit my 96" TC ???
Old Apr 1, 2013 | 09:11 PM
WhereduGo?'s Avatar
WhereduGo?
Originally Posted by fxdxsteve
yes they will I have a thunderheader from an 87 fxr on mine I had to fab a bracket to go from my stock rear mounting bracket to the muffler but it works fine I paid 40 bucks for the thunderheader at a swap meet
I guess the old google will do you good ....
Old Apr 1, 2013 | 09:41 PM
tree88's Avatar
tree88
yes they will fit on the engine (I run evo softail pipes on my twincam dyna) but you may need the older style flanges (depending on your bike's year model) (cheap) and you may also need to add o2 sensor bungs into them (cheap if you can weld- not so much if not). the exhaust bracket will most likely require some "creativity" to get it to fit the newer (once again- depending year) bike. hope that helps
Old Apr 1, 2013 | 10:10 PM
WhereduGo?'s Avatar
WhereduGo?
The pipes are very short warlocks and do not require any type of mount to the frame they only mount to the cylinder heads and are help together with a brass coupler so to speak. They are going to be crazy loud I think I just pickup up my street bob Friday and cant stand how quiet it is. Im going to weld some 12mm bungs into her and give it a shot, now what type of flanges do the 13s have?
Old Apr 1, 2013 | 10:31 PM
tree88's Avatar
tree88
they have a thicker flange than was used previously- they *may* work with those pipes, but I would look into purchasing a set of older style (just look for an evo flange and clip set) flanges- just to save yourself an "aww sh-t" moment. depending on the style of pipe, you may still run into chassis issues- if they were meant for a softail, or sportster (yes, some of those will fit as well) the front pipe should be easy, but the rear (if they are "s" bent) may block the oil fill/ dipstick- so test fit for sure. I tried looking up "harley warlock exhaust" to get a pic, but had no luck- a picture would be useful in pointing out any obvious fit issues, and ways around them.
*tragic*
Jan 13, 2014 11:18 AM
66LOW
Nov 23, 2011 03:47 AM
ronnyvous1
Jan 22, 2010 09:14 AM
jakazz
Exhaust System Topics
Sep 6, 2007 09:32 AM
KY REBEL
Dec 7, 2005 03:33 PM
