twincam - evolution
Old Sep 1, 2007 | 12:39 PM
jakazz's Avatar
jakazz
Default twincam - evolution
I was chating with a guy at bike nite, and he said that the jugs and heads off a twin cam would fit an evo motor......Any input would be appreciated
Old Sep 1, 2007 | 07:20 PM
mentor70's Avatar
mentor70
Default RE: twincam - evolution
I dont think they will, Im positive the bore and stroke are plenty different!
however, the rockers, are the same and valve springs on the pre 05s.
Old Sep 1, 2007 | 10:33 PM
Y2K's Avatar
Y2K
Nope,not a bolt on deal but it can be done just like the old Shovester with some special parts and machining.
Old Sep 3, 2007 | 02:21 PM
big cahuna's Avatar
big cahuna
I had a web site that explained how to do that but I lost it. if I remember you need to bore the evo cases to fit the twin cam jugs using the 95 in pistons with the stock evo sroke would get you 100 cubis inches. they also said you have to mix and match the pushrods to get them to fit.if you have alot of odd and end parts with no home it would be fun to do.might not be cheap, but you'll get some strange comments as to what motor is that?.,,,,
Old Sep 3, 2007 | 05:04 PM
sporty79's Avatar
sporty79
S&S makes cases that allow you install a Twin Cam motor in an Evo frame. You would use the bottom end components from the TwinCam engine as well. Might be cheaper than machining the Evo bottom end to accept the Twin Cam jugs.
Old Sep 5, 2007 | 04:27 PM
Kingofcubes's Avatar
Kingofcubes
I bought a couple of left over cases from S&S for this if anybody is looking for them, I believe they have been discontinued.
Old Sep 6, 2007 | 07:40 AM
rodmodder's Avatar
rodmodder
I'm running a 95" S&S Tc on an evo mount in my 98 heritage. Works good.
Old Sep 6, 2007 | 09:32 AM
ReeseSS's Avatar
ReeseSS
The spacing of the cylinder studs on the TC are different then the EVO so the jugs and heads will not bolt on.Will not match the case.
REW13
Engine Mechanical Topics
Dec 23, 2017 04:59 PM
grieker
Oct 23, 2014 08:53 AM
motorwolf
Jun 5, 2011 09:52 AM
McCormack090305
May 14, 2011 08:59 PM
Just Enough
Apr 30, 2011 06:51 PM
