Popping?
Old Dec 12, 2011 | 05:07 PM
parks1955's Avatar
parks1955
Stage II
Default Popping?
I have a 2004 Softail Standard injected all stock with 6500 miles. I am getting some popping as I back off the gas and some times I will get a small back fire when I start it up and the Mileage does not seem to be what it should be. I replaced Plugs,Wire's and the Air Filter no change. The Bike runs pretty good and is not throwing any Codes but........
Old Dec 12, 2011 | 05:30 PM
checkers's Avatar
checkers
Clean and tighten your battery cables and change fuel supplier. Try to find a gas station that has premium fuel without ethynol. Fuel quality today is poor and your ecm will calibrate itself down for poor fuel. I would also buy a bottle of Chevron Techron fuel system cleaner and install about 4 oz into tank and fill. This stuff works. Previous Harleys I have run(TC's) I would get 48-51 mpg, my 2011 Heritage, lucky if I get 42-44 MPG. Same riding same area and same gas stations, ethynol fuel and fuel in general is poor.
Old Dec 12, 2011 | 05:36 PM
colonelangus1's Avatar
colonelangus1
exhaust leaks is a major cause of popping only run premium gas
i only run 94oct unless i cant find a chevron then its 92oct which is everywhere
ive had decel popping in past always been a leak usually at the donut just my .02
Old Dec 12, 2011 | 06:39 PM
priceamp's Avatar
priceamp
Check for exhaust leaks at the heads and where the mufflers attach to the head pipe. Muffler clamps are susceptable to leaking.
Old Dec 13, 2011 | 05:14 AM
parks1955's Avatar
parks1955
Stage II
Thanks, I will break out the Troque Wrench this after Noon. This might just be a good excuse to upgrade the Exhaust.
Old Dec 13, 2011 | 10:10 AM
oct1949's Avatar
oct1949
More info would be nice,..
like did this just start or been doing it a while.
have U changed anything else other than filter and plugs.
Usually its either the tune or Air leaks that cause popping.
What F/M system do U have,? has it been dyno tuned,?
The backfire when starting in not unusual on a bike up to temp on restarts. Like gassing up and then restarting her.
heritageblue2013
Oct 30, 2015 01:13 PM
mgmmgm
May 14, 2012 03:50 AM
k-hook
Apr 30, 2011 07:19 PM
lowhog56
General Topics/Tech Tips
Sep 3, 2010 11:43 PM
trackadaptor
Aug 18, 2010 02:31 PM
