Remove Stem From Bracket
Old Jan 11, 2012 | 08:05 AM
Il_Pres's Avatar
Il_Pres
Default Remove Stem From Bracket
Hi All,
I'm trying to mount the Harley Springer Rake Kit provided by Vulcanworks.
http://vulcanworks.net/store_4/produ...3&cat=0&page=1
Everything is OK so far, but I'm facing a big problem from now on: remove the springer fork stem from lower brackets. The service manual doesn't help, nether the vulcanworks mounting instruction (it just says to PUSH the stem away). I'd like not to break or ruin something using some hammer or heating here and there... any official guide?
Grazie !
Old Jan 11, 2012 | 12:28 PM
brettnbama's Avatar
brettnbama
what model are you putting this on? I see they list the 7.5 degree kit for the Crossbones. Anyone tried this thing out? If you are putting it on a Crossbones, I really am interested to see how it works out for you.
Old Jan 12, 2012 | 02:45 AM
Il_Pres's Avatar
Il_Pres
I'm putting the 4.5 deg. But I'm not finding useful info to separate the stem...
Old Jan 12, 2012 | 12:03 PM
brettnbama's Avatar
brettnbama
wish I could help. If you do get it figured out please post a ride report
Old Jan 12, 2012 | 03:42 PM
Scott Hall's Avatar
Scott Hall
I'm about to order the 7.5 kit for my Bones trike project. Reading the HD service manual I thought the stem would just slide out. Maybe quiz your local dealer to see if they've removed a springer front end recently. I'll keep an eye on this thread for my installation. Please keep us informed of any tips, tricks, or pitfalls you encounter. Did you take any side on pics with the stock set up for comparison?
Thx,
Scott
Old Jan 13, 2012 | 02:50 AM
Rakthi's Avatar
Rakthi
Looked at it on my Xbones and I think it is a press fit item, even if it has the circlip to hold it in place.
You might be able to "push" it out with a "Pulley Puller" .. worth a try.
Old Jan 13, 2012 | 05:47 AM
Il_Pres's Avatar
Il_Pres
Thanks all...
I've written to Vulcan and they've kindly answered:
You press the stem out by putting pressure on the top of the stem and pushing it down through the bottom tree. Sometimes you can rap it out with sharp blows with a heavy brass mallet, and, sometimes it needs to be pressed out.
I think anyways that I need also to remove the lower bearings, that, as per service manual, needs to be heated. Will try in the weekend and let you know.
Old Jan 13, 2012 | 09:17 AM
Scott Hall's Avatar
Scott Hall
Jims has a tool for this, I don't know what bearing the FLSTSB uses:
FORK STEM BEARING REMOVER
Use this tool to remove the lower fork stem (Triple
Clamp) tapered bearing.
No.
1414 - Use on all lower fork stems that use a
H-D
® No.48300-60 style bearing. Order
JIMS
® Hard End Cap, No.1048 when
using on early XL 1978-81.
Old Sep 28, 2012 | 07:36 AM
clive_frog's Avatar
clive_frog
Stage IV
Originally Posted by Il_Pres
Thanks all...
Just Done my 2005 FLS classic with the 7.5 deg kit.
The Stem does not push out unless you have a very good hydraulic press.
I ended up by cutting the stem off flush with the lower mount using an angle grinder, then drilling out the center to 13mm, which is just big enough to fit in a hacksaw blade and cut a groove in the remaining material and it then just taps out.
Prior to this I tried all sorts of heat treatment and bashing with varing sized mallets, but to no avail.
travis dasher
May 24, 2010 07:11 PM
Theo
Oct 6, 2009 01:46 PM
calbertson
Jul 17, 2009 10:25 AM
joeugly
May 23, 2009 06:16 AM
