Cycle Visions Eliminator review
Hey guys,
As some of you might remember from my posts last week I was having battery issues and all that but thankfully that got all sorted out and have been having no more issues in that department.
This saturday FedEx arrived with my new cycle visions eliminator which I installed on sunday with some help form a firend of mine. All in all I have to say that the install was straight forward and relativly easy. I did some homework before I started and am glad I did due to some extra steps that if I didnt know about, I would have be aggitated with and probbly thrown something. lol Here is the process I went through to put it on the 2010 fat boy lo. The red steps are out of the ordinary things I had to do that I wasnt expecting.
-removed the tail light and the easy brackets laydown plate with turn signal relocate that I had on the bike previously.
-cleaned the rear fender where the new assembly was going to go.
-bent the tabs out a little on the bottom of thecycle visions backing plate to allow it to clip onto the lip of the hole where the old tail light was.
-attached the backing plate with the new screw provided.
-Trimmed my licence plate edges to get it to fit inside the new cover plate.
-Took a dremel and cut down the shorter end of a 5/32 allen wrench due to lack of access area between the eliminator and fender.
-used electrical tape to secure the unused plug in the new wiring harness to the rest of the wires and secured it to the clip under the fender to prevent rubbing on the rear tire
-hand started the allen bolts to get everything alligned and then tightened down the bolts with the trimmed allen wrench
-took off the seat and plugged the load equalizer into the wiring harness.
-Tested the new system for function
It took a little longer than planned but the install wasnt hard at all and just took som patience. now for the after thoughts:
THIS THING KICKS A$$!!!!!!!!!!!
The led's in the unit are much brighter than expected and there is a white strip to illuminate the licence plate. The 4 flashes that you get when you first apply the brakes are a great safety feature that really gets attention. The turn signals are amber in color when activated but the all the run lights are red. I cant believe how well this cleaned up the rear fender compaired to my old set up. I dont have any decent pictures right now but will have some up soon once the bike is cleaned up. Once again this thing rocks.
hogcommander
Electrical/Lighting/Alarm
09-09-2009 11:08 AM
