engine breaking
Old Mar 17, 2012 | 08:20 PM
jlasoftail's Avatar
jlasoftail
Default engine breaking
Ok guy, here's the question, and it just kinda came to me after reading something in an exhaust thread. My bike really doesn't seem to slow down when I let off the throttle. Would this be caused by the tuning, my long pipes, my cam...? It's been making it harder to ride around corners without hitting the breaks.
Old Mar 17, 2012 | 08:27 PM
Superfly3176's Avatar
Superfly3176
Is your throttle sticking at all? Your bike like anything should slow down when leaving off the gas.
Old Mar 17, 2012 | 08:30 PM
jlasoftail's Avatar
jlasoftail
No, not a throttle issue, it just seems to coast a lot more then it should. Any other bike I ride seems to have a lot more back pressure slowing it down...
Old Mar 17, 2012 | 08:32 PM
Superfly3176
Your not pulling the clutch in while doing this right?
Old Mar 17, 2012 | 08:36 PM
olongapo1's Avatar
olongapo1
Perhaps you're in too high of a gear. Try down shifting prior to entering the turn.
Old Mar 17, 2012 | 09:00 PM
PanHeadRich's Avatar
PanHeadRich
What RPM is your idle set at? If it's idling too high it would have that effect as well.
Old Mar 17, 2012 | 10:24 PM
Honey-Badger's Avatar
Honey-Badger
Lmao...
Originally Posted by superfly3176
your not pulling the clutch in while doing this right?
Old Mar 18, 2012 | 06:15 AM
Benway's Avatar
Benway
Sounds like high idle.
Old Mar 18, 2012 | 07:03 AM
jlasoftail's Avatar
jlasoftail
Originally Posted by TheBlackPharoah
Lmao...
lmao, no, I'm pretty sure that's not the problem. It likely has more to do with what gear I'm in. I guess after putting the 255 cam in, I'm running at lower rpms then I used to. Could also be high idle, never thought of checking that. I'll mess around with it a little and see if I can get some better results. What should a normal idle be?
Old Mar 18, 2012 | 12:03 PM
PanHeadRich
I believe Harley advises the idle of the twin cam rpm to be 950 to 1050, but hopefully others can confirm this.
