The upswept doesn't flow well in a 2-1 pipe. The first does look like the RSD Tracker system but that's not a bad thing. I think it would look better. I liked your old upswept pipes w the black wrap. Maybe try the first design and make it your own with black wrap.
The exit end of a Thunderheader has a stepped cone on it. Your pipe looks like a Rush or D&D type end. If you look at my attached pic you can see the stepped cone at the end of the pipe, it is about 6" back from the end. A Thunderheader will also not have any baffles that are removable in it.
But I like the RSD look. If I were to get a new exhaust it would be the RSD pipe, may not give me the power of the Thunderheader but it looks good. Good luck on your project.
Pipes are done, will post pics when the paint dries & I get them wrapped.
Trust me it's a thunderheader. I cut the resonator off the end cuz it's ugly.
