any of you guys have an easy solution, or do I need to wait until tomorrow and try to find one at an auto parts store? I don't feel like paying the HD price and I'm not pulling my exhaust off to get at them. I'm sure there's got to be some easy homemade tool options...
Yeah, I've had the pipes off and on enough times (two beer job for me), but was hopping to avoid it. I don't think even a normal o2 wrench will do the trick since the pcv auto-tune sensors are a fair bit longer. I might take a socket to a welding shop and get it lengthened then grind a slot in it. At least then I'll have one more tool to add to the collection. I was thinking there might be an easier way, but I guess I knew there wouldn't be.
find a tool guy at a garage and get one, they have short ones that work great. I have like 4 of them to get sensors off cars. If you make one use a black socket as the walls are thicker
I broke down and bought one, just got back so not sure if it'll work yet. It's a short offset one. I'll report back later after my auto tune is in. To bad I wasted the time and money buying a deep socket and cutting a notch threw it. I would work to take the older ones out, but not the new, longer PCV ones.
I know you already bought one..to remove the O2 sensors from your pipes while they're mounted? I just used a small open ended wrench on mine..
I looked at that option, but there was no room at all. Not sure if maybe they are mounted a little different on my pipes. Anyways, I got them off with the offset sensor wrench. The only trouble I ran into was that I had to take the seat post off. There was so little room that I can't imagine any wrench fitting through the opening. It wasn't a big job, and only took about 1/2 a beer. Pipes take two beer, so all said, I think I went about it the right way. Hmmm, now with all that extra time I have, I might go finish that beer... lol
PS: I suggest you all take a minute sometime and check your sensors. My rear was no more then hand tight...
