Valvetrain noise?
Once it gets warm, anything around 2000 rpm in a higher gear makes a "rattle" noise. Kinda sounds like either chain slap or valvetrain clatter. Downshift and it goes away. Doesn't do it when cold for the most part. Not detonation, running premium gas, fresh HD oil in it.
Is this common to the 96"? Buddy's 2003 88" is quiet.
One of the reasons I sprung for the extended warranty.
Bought the manual for it, so guess I'll start poking around.
IMO if U brothers bike has went through three sets of tensioners on a 09,, Then IMO something else is wrong..
Tell us more about the bike, built motor??, how many miles on it?? U sure its an 09?
At 11k on a 07,,, A tensioner issue/failure would be REALLLLLY RARE.
the 88'' motors does have issues with tensioners.
Even on a 88" er having them going bad at 11k would be RARE but it has happened.
Read up on the 96'ers and how the new tensioners with roller chains are doing.
here one from here..
https://www.hdforums.com/forum/touri...ensioners.html
Ive read of only one member that changed them with 80k on his bike, only because he wanted to when he put in new cams, still He stated they where not worn much at all.
Now as far a some rattle noise, every Harley Ive ridden does make some lifter noise, the more U listen for it the louder it will get.
Its not impossible to have an issue of some sort, but more than likely it just the normal lifter noise Ur hearing.
Maybe,,, For U own peace of mind just take U bike in and have the tensioners checked. The way U'll know for sure what shape their in and U'll ride feeling better.
What I don't know is why the 96in motor doesn't like <2000 rpm in higher gears. Not that I'm lugging it, but it just doesn't seem to have the "grunt" that I thought it would have. Kinda weak feeling til you wind it up a bit. My 1100 Shadow would pull down more and still not complain as much as as this much larger HD motor. That is what I wondered.
All my car hot rods have solid lifter cams, so valvetrain noise is good with me! Love the clitter/clatter actually. This just didn't seem right, so I was questioning it. I bought a inspection cover gasket and I'm going to peek inside to see how the chain is. For a couple bucks, I'll do it. Won't be taking it in anywhere to have it looked at, that's all up to me. More then capable.
As for oil, it has HD oil in it, pretty sure it's not full synthetic. Have to find the extra qt PO gave me when I bought the bike.
BTW, that link for tensioners was for CAM chain. I'm speaking of Primary chain, which is still just spring loaded.
I love loud exhaust, but no ear plugs for me! Though it's not as obnoxious as some.
Thanks for all the replys.
