Stator Replacement
Old Jun 4, 2012 | 12:48 PM
tommyq02's Avatar
tommyq02
5th Gear
Angry Stator Replacement
I have scoured the entire world wide web and have come up empty handed. I need to replace the stator in my 97 Fatboy. I have everything torn down and ordered a new kit off ebay.
Heres my issue. I cannot for the life of me get the plug back through the block. I have used grease, primary oil, chain lube, even shed a few tears in there to see it it would show mercy for me.
Long story short the bike hates me and I have screwed up my new stator plug . Everywere I have read and videos I have watched says just to "pop it on through". They must be hercules because I can get it to about the first rib of the plug and thats it. New stator is on order and I will continue to practice with the one I have ruined. But if someone can please tell me the trick to simply pop this plug right on through it would be greatly appreciated.
Thank you in advance
Old Jun 4, 2012 | 02:37 PM
tommyq02's Avatar
tommyq02
5th Gear
nothing?
I know someone here has done a ton of these and knows the trick.....share a little
Old Jun 4, 2012 | 02:56 PM
merdahl's Avatar
merdahl
If you are sure you have the right one, spray a little silicon lubricant on it. Mine slid right in.
Old Jun 4, 2012 | 03:05 PM
Mike NY's Avatar
Mike NY
Does the new plug look like the one you removed? Are they the same size? If it fit coming out it should fit going in....
Mike
NY
Old Jun 4, 2012 | 03:18 PM
tommyq02's Avatar
tommyq02
5th Gear
plug is different as its not HD made but rather aftermarket. Plug are same size however different design. I may just go back with an HD stator.
However that leads me to the next question of will my new rotor from the charging kit fit a HD stator?
Old Jun 4, 2012 | 03:50 PM
S.D.M.F's Avatar
S.D.M.F
Here's a link to a 9 part video showing how to remove and replace a stator:
http://www.youtube.com/watch?v=GXI5wZ4_PFU
Hope it helps.
Old Jun 4, 2012 | 04:53 PM
mac1911's Avatar
mac1911
I would use HD parts. Almost always found they fit and work.
Old Jun 4, 2012 | 05:21 PM
tommyq02's Avatar
tommyq02
5th Gear
Thanks for the video post. I watched it several times while waiting for the parts to come in. Actually how I was able to do the tear down. I think its just an aftermarket crap product. I'll go back with HD and see if I have better luck. Should have known better than trying to get around making a donation to my local dealership. They may get me on parts but not on labor. Lol
Old Jun 4, 2012 | 07:18 PM
Stretchman's Avatar
Stretchman
For what it's worth, there's also an EVO classic forum. They might have seen something like this before. You might want to drop in there. Just check the forums link at the top of the page, under Harley Davidson Motorcycles.
Old Jun 4, 2012 | 10:59 PM
Bluehighways's Avatar
Bluehighways
I'd suggest that you use the original HD Part Number and try some of the On-Line Dealers: Lakeshore HD, NewCastle HD, Surdyke HD, etc.
