Calling all Springers!
Old Sep 10, 2015 | 12:35 PM
  #701
FLYING_BURRITO_BROTHER's Avatar
NOT A MODERATOR
Originally Posted by Joe_G
Holy smokes that is SWEET!! I wonder if Music&Bikes has seen this. He's modding up his Bones.
I have the Train look as well with the BigFrigginHeadlight mod. I've often considered the sprung seat like yours but I take some long trips with mine and that backrest is outstanding. Do you do any long trips (say couple of 400 mile days) with yours? Comfort level?
Thanks man! It's taken me 6 years to get to this point with the bike...I have been patient and picky about the look I wanted. You have a great looking bike too...more set up to tour with.
The most mileage I've done is 380 miles round trip in a day, curvy mountains and back hwys. For me, the sprung seat is very comfortable. The most discomfort I have would be the same as sitting at a desk all day. The need to stand up at a stop light once in a while is all it takes to cure that. This seat has less padding than the original thick tractor seat that came on the bones. It's not the padding that makes it comfortable...it's the shape. The repro WLA seat is shaped very well and is super comfortable. Honestly, I would never consider this bike for touring. Not because it's uncomfortable...it's just impractical. That and I have the softaillowering kit on it which obviously reduces rear suspension travel.
This is how my bike looked when I got it... Man...what a difference!
Old Sep 10, 2015 | 12:37 PM
  #702
RandallJ's Avatar
RandallJ
Got a lot of hours on a tractor seat (on an old ford tractor) if the bike version is anything like the real thing, it should be good for all day in the saddle.. gonna have to try me one
Old Sep 10, 2015 | 04:19 PM
  #703
sober1's Avatar
sober1
Default oh, what the hell
My 08 CrossBones<br>she ain't really purdy but she can sure fight!<p><p><img src="http://photos.imageevent.com/tmike/foid/large/IMG_32333.JPG" width="533" height="800"></p>
<p><img src="http://photos.imageevent.com/tmike/foid/large/IMG_3232.JPG" width="800" height="533"></p>
<p><img src="http://photos.imageevent.com/tmike/foid/large/IMG_3235.JPG" width="800" height="533"></p>
<p><img src="http://photos.imageevent.com/tmike/foid/large/IMG_3234.JPG" width="800" height="533"></p>
Old Sep 10, 2015 | 04:45 PM
  #704
Bigdad24-7's Avatar
Bigdad24-7
4th Gear
If I can figure out how to load my pics I will show off my baby too! 98 Softail Springer. Love me some springers!
Old Sep 10, 2015 | 08:06 PM
  #705
Bigdad24-7's Avatar
Bigdad24-7
4th Gear
98 Softail Springer
Old Sep 10, 2015 | 10:27 PM
  #706
Ink83's Avatar
Ink83
Burrito brother
Sober1
Bigdad
Bikes looking good fellas
Burrito that seat does look pretty damn comfy! Those pipes have baffles?
Sober1 by fight you mean it's got engine work?
Old Sep 11, 2015 | 12:29 AM
  #707
sober1's Avatar
sober1
SE Heavy Breather, SE 255s w/ Hammer Perf. Pushrods, D&D Low-Cat, V&H FP, 30/70 Pulley Conversion, M6 Chain Tensioner to date. I've done all performance mods so far by myself. The filled in rear 07 Fatboy Fender was leaded by my brother-in-law Kevin and painted by his son, my nephew Erick. Next up , FI mods then Oil Pump upgrade, then braking system upgrades when funds permit. Back in the day my Scoots took hours to clean, now a days they get washed when it rains. I ride it like I stole it!
Old Sep 11, 2015 | 12:47 AM
  #708
NOT A MODERATOR
Thanks man... Nowhere NEAR the level of awesomeness and craftsmanship of your bike!
Seat is very comfy. As mentioned earlier, it is a full size "tractor" seat. Wouldn't look good on a bike such as yours (even if it was black), it's too wide for your slimmed bike. Pipe did come with a baffle...but it's pretty small. It's not too loud until you twist the wick.
Old Sep 11, 2015 | 05:16 AM
  #709
Ink83's Avatar
Ink83
That sounds pretty tough man! Changing my sprokets for more off the line was one thing I wish I done, did you do a before and after with this mod see the difference or did you do it along side the other mods? Another thing I really need to get sorted like you said is get a high volume oil pump in
I just ordered the SE high comp 110 kit, I can't tell you how pumped I am to give it a lashing! I went with the SE 259e cams, SE lifters push rods and springs and injectors, figure machine velocity stack, had the heads and TB sent away to be ported polished and port matched then bench flowed, TB mm was stretched a little larger and the heads also had over size valves done along with the deck shaved for 11:1 compression. My pipe is what's going to kill getting the best out of it though, might change it if it's real bad. Though being in a softail that only weighs the same weight as the lighter sportster models, no matter what pipe is on it should still be a lot of fun to thrash
As for brake check out the lyndall racing brakes rotors, suppose to be the ducks nuts, plus you can get the full rotor in a black ceramic composite. I went with their black 13" floating ceramic rotor, gold LRB pads and PM 6 piston caliper for the front, and I tell you what that rotor is crazy light weight, like maybe a couple hundred grams at most, awesome bit of gear.
Haha thanks for the kind words man! I probably should of bought a xbones, they come the most bad *** straight from the factory, I really mean it you guys have done a great job making them even cooler
Yeah you're right about the seat, I had to shape may seat fairly narrow to work with that skinny tank. But this was only intended as a "bar hopper", or for quick thrashes to the next city and back, so comfort came second to looks. I will build another bike that's for longer distances.
I'm curious how do you find the sound with that pipe? Is it like a 2-1 sound or more of a drag pipe sound or just unusual? I'm curious because obviously mines very simliar but I haven't heard it yet. The rear pipe enters the main section a little different which I guess could alter the sound a bit in comparison. The megaphone like shape gives me the impression it's going to be super loud too, is this the case?
Old Sep 11, 2015 | 12:46 PM
  #710
NOT A MODERATOR
I love the sound of the pipe. It's got a good snarl and more an unusual sound. Probably closer to a drag pipe but not that loud. It's got a lot of burble and pop, which i LIKE. I bet yours will have less pop because of the equal lenghts. The side exit "megaphone" is always setting off car alarms as I pass by even at lower RPMs but I don't think it's because of the loudness. Sound is such a hard thing to describe in words.
Because of the very uneven lengths of the cylinder exit pipes it was a bitch to tune (I finally had to have it dyno tuned). PowerVision which was great when I had Rush slip ons was worthless for this pipe.
It's not a great pipe for performance...and I don't care. If I wanted fast, I'd buy a Ducati. I'll be interested in hearing the results of your pipe...It is really awesome looking.
The other pipe I was considering was teh Yaffe Skirt Blowers...but I went with the Covington because it is just so unique and reminds me of a V8 hot rod exhaust.
