winter troubles
Old Jan 14, 2007 | 01:32 AM
wildbill2's Avatar
wildbill2
Stage I
Default winter troubles
Hey my bike runs like crud in could weather
I changed the plugs, and warmed it up real good .
I am talking about 30-40 dagree. weather..
also it seemed to have a little bit of white smoke blow by.
I have about 21000 mlies now .
..One fellow at the local bike shop said dont run Harleys in this kind of weather..
I Thought hey my brother road his 45 flathead in the snow to a family X-mas one year..Dont tell me
not to did in could weather..Whats do ya think
Old Jan 14, 2007 | 01:36 AM
04harleyboy's Avatar
04harleyboy
Default RE: winter troubles
You may want to refer to the manual, have you changed the weight of the oil your using. I believe they recomend 10W40 below 40 degrees. Just a thought.
Old Jan 14, 2007 | 09:11 AM
Grey Biker's Avatar
Grey Biker
Wild Bill, You said you changed the plugs, Did you use the same heat range? You didn't say if your bike had a Carb. or was F.I. Assuming you have no other mechanical problems a one heat range hotter plug, and or one size bigger carb. jet will make a big difference in cold weather.
Old Jan 14, 2007 | 09:12 AM
monkyman's Avatar
monkyman
What year is your bike? I believe that 06's had some cold injector problems, switched to a different type.
Are you actually riding the bike or just starting it to keep the battery charged? If your not actually going to ride the bike, don't keep starting it just to hear it run, you are going to keep dumping fuel into the motor by running it full rich and wash down the cylinder walls, also contaminating the oil as it will never warm up enough to burn it out.
I have a hard time starting in 30 degree weather, let alone my bike!
Old Jan 14, 2007 | 10:07 AM
Heritage07's Avatar
Heritage07
Whoever told you not to run a Harley in 30 degree weather is an idiot!
Old Jan 14, 2007 | 05:10 PM
XTrooper3936's Avatar
XTrooper3936
ORIGINAL: Heritage07
I'll second that. I've logged hundreds of miles on my '07 in 20-30 degree F temps and it always ran like a champ.
BTW, using the "normal" weight motor oil (20W50) in colder temps will only be a problem at startup, if at all. It's not going to have any effect on how your motor runs at normal operating temps.
Old Jan 14, 2007 | 09:58 PM
mdewberry's Avatar
mdewberry
Shoot, I just screwed 500 screws in my rear wheel so I could ride in a ice storm!!!!! Too cold to ride? If your scared to ride in the cold, I hear those goldwings have heaters,defrosters, coffee makers, foot warmers, heated back massagers.. LOL Just having Fun
Old Jan 14, 2007 | 10:37 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: mdewberry
That's the "Cooler Season" option on the BMW's not GoldWings. The GoldWing'sback massager isn't heated.
Old Jan 15, 2007 | 12:51 AM
nikonf8's Avatar
nikonf8
My bike runs absulotly great in cold weather. never had a problem I have logged in quite a few miles in the 30 to forty degree range and it runs strong .
jordanball33
Nov 22, 2015 08:21 PM
atwa
Oct 4, 2012 10:27 AM
badbs101
Nov 15, 2009 02:23 PM
Ruger
Nov 28, 2008 07:54 PM
saltlick
Sep 26, 2006 11:59 AM
