Front forks
Old Jul 12, 2012 | 08:28 PM
jakazz's Avatar
jakazz
the lower pinch bolt is loose
Old Jul 12, 2012 | 08:47 PM
Tracker56's Avatar
Tracker56
Originally Posted by ajtaylor812
I know the the top pipe turns freely. How would I prevent this from happening again?
AJ
That top tube shouldn't turn at all. The lower triple tree has pinch bolts that secure the tube. That must be loose for it to turn and needs to be tightened before you ride it again. Check the other side while you're at it.
Old Jul 15, 2012 | 04:54 AM
bartallica2006's Avatar
bartallica2006
Yeah the cap is missing, lower tree clamp loosened, fork tube is coming out!
Old Jul 31, 2012 | 06:44 AM
ajtaylor812's Avatar
ajtaylor812
Default Update and done
That pinch bolt was SHEARED! Got it out, replaced, and put back together. Running great! Thank you all for your help.
Old Aug 4, 2012 | 06:44 PM
cowboybob56's Avatar
cowboybob56
Cool Dude should you have gotten a manual?
Sometimes we ask questions not covered in the manual, sometimes.
bmcgc
Nov 21, 2010 08:38 AM
JayDee5150
Aug 3, 2009 05:01 PM
The Baron
Feb 25, 2008 11:28 AM
twilliams
Jan 6, 2008 07:01 PM
