Running lean.....
Old Jul 21, 2012 | 07:55 PM
Bushwacker's Avatar
Bushwacker
6th Gear
Default Running lean.....
Hello all, I am a new member on this board! Need a little bit of help. I have a 2004 Softail FXSTI, that I hopped up over the winter. (ported heads & went from an 88 to a 95 in cams)
A few weeks ago, after I installed my power commander, I took it to be tuned, and realized I had an intake leak. Fixed that issue, and when I went back to be re-tuned, at first everything was great. We tuned the front cylinder, then when we went to the back, things started acting up. At first it acted as if I had another air leak, then all of a sudden, it went from 90 HP to 66 HP like someone flipped a switch. Rechecked the front cylinder and it went from being correct to running very lean. the rear was also lean but was never correct. Rechecked for air leaks at the manifold, injectors and throttle body, and also head gaskets, with none detected. Bike still runs but not well.
Any suggestions on what the issue could be is much appreciated!!!!!!!
Thanks
Old Jul 21, 2012 | 08:22 PM
QC's Avatar
QC
Does it run better without the PC?
Old Jul 21, 2012 | 10:09 PM
Bushwacker's Avatar
Bushwacker
6th Gear
No unfortunatly it runs worse we tried unplugging the power commander and plugging in the stock ECM while on the dyno and it got leaner
Old Jul 21, 2012 | 10:19 PM
QC's Avatar
QC
You could give Jamie at FuelMoto a call Monday to see if he can help you out. Maybe some one else in here will chime in. Have you tried a map from Power Commander's site?
Old Jul 21, 2012 | 10:43 PM
Bushwacker's Avatar
Bushwacker
6th Gear
Tomorrow I am going to do a compression test, fuel pressure test, and put on my V&H fuel pack to see if they lead me down any paths I will keep you guys posted on my findings
Old Jul 21, 2012 | 10:53 PM
QC's Avatar
QC
And Welcome to the Forum from Colorado! Good luck.
Old Jul 22, 2012 | 05:21 PM
Bushwacker's Avatar
Bushwacker
6th Gear
well... discovered there is a leak in the fuel line.
Old Jul 22, 2012 | 05:50 PM
QC's Avatar
QC
Well, that would cause your symptoms. couple threads in here about it.
Old Jul 22, 2012 | 05:59 PM
dennyo's Avatar
dennyo
I guess your talkin about the one in the Tank , That should be an easy Fix ,
Old Jul 23, 2012 | 04:48 AM
Bushwacker's Avatar
Bushwacker
6th Gear
Yes it will be but still thinking on how to sheeld it to keep it from happining in the future
