Blackline Triple tree
Old Aug 5, 2012 | 10:27 PM
Softailbill's Avatar
Softailbill
6th Gear
Default Blackline Triple tree
Hello I'm new to the forum I have the new blackline was wondering if anybody has put on the new triple tree from Todds cycle is it something that requires special tools or can someone with moderate Mechanical skills pull off
Old Aug 6, 2012 | 07:31 AM
Blackliner2012's Avatar
Blackliner2012
Stage III
Pull up a you tube video to see how to change the triple trees or how to change the springs in the front tube fork. That should give you some idea on how it's done.
Old Aug 6, 2012 | 06:36 PM
jreichart's Avatar
jreichart
Not hard to do at all, as long as you're not changing the bearing races. Basically remove front wheel, remove forks (pinch bolts and top cap), remove steering head nut and the trees will come right out. If you've got some miles on it, replacing the bearings would be a good idea while you've got it torn down. Follow instructions with new trees, reinstall forks and front tire and adjust the "fall away" and it's done. Basic tools, torque wrench, and you'll need a big socket for the steering head nut, can't remember the size.
Old Oct 1, 2012 | 08:33 PM
TheGriz's Avatar
TheGriz
Good info, just ordered a new triple tree from Todd's. Cant wait to start pulling it apart!
Old Oct 1, 2012 | 10:18 PM
LtJGMLD's Avatar
LtJGMLD
1st Gear
Doing this too.Can't wait to take it apart.
Ridewva
Oct 4, 2016 12:47 AM
trainedkilla
Sep 13, 2013 07:59 AM
GlobeWarmer
Aug 12, 2013 02:02 PM
schwangster
Apr 4, 2009 01:00 PM
speed8988
Jan 18, 2007 06:38 PM
