Figured It Out
Old Aug 7, 2012 | 07:49 AM
RANGER73's Avatar
RANGER73
Default Figured It Out
I had posted a question about banging under the seat when I hit a sharp dip.
Being this is my first bike, there is a lot to learn. Turns out it was the swingarm bottoming out against the frame under the seat. I needed to adjust the shocks firmer, plus I had installed lowering shocks and slammed it to much (making it a hard tail). Now all is right with the world (as far as my bike goes).
Old Aug 7, 2012 | 08:07 AM
Haxxor's Avatar
Haxxor
I'm fairly new too, and there is definitely a lot to learn. Thanks for posting, you probably saved me from making a panic post later.
Old Aug 7, 2012 | 08:12 AM
NDBadlands4-2's Avatar
NDBadlands4-2
You must have really slammed it, or hit those speed bumps at speed. With it that low did you ever scrape the frame? My Night Train was very low when I bought it. I never remember bottoming out the suspension, but I scraped the frame several times before I raised it up.
Old Aug 7, 2012 | 11:56 AM
RANGER73's Avatar
RANGER73
Ya I was hitting before I installed the lowering shocks, not knowing that the shocks are factory set for light weights. Then I slammed it way down, I'm 260lbs and still not realizing the shocks were not adjusted for fat asses, I had no suspension at all. And I did scrape the frame on tight turns. A lot of reading on this forum made me realize where I screwed up. And Like I said "All's good".
And my back is grateful too !!!!
82flh
Apr 2, 2010 09:18 AM
JockWhisky
Jul 12, 2009 07:55 PM
Wide06
Oct 2, 2007 04:42 AM
dakotacrk
Oct 25, 2006 08:07 PM
Beefcake
Jun 14, 2005 01:57 PM
