The details will take a lot longer. Styling, add ons, seat height, etc. are all different. Go to www.Harleydavidson.com and hit compare bikes. It will let you select these three bikes and you can see the details of the difference. Stop in the Stealership and sit on each one, you will immediately know the difference.
Custom and standard very similar, mainly cosmetic differences but
plenty of difference to deluxe. Check out the pictures in the softail sectionhttps://www.hdforums.com/forumid_6/tt.htmthat will give you some idea.
Like the others said: Besides money, lots of difference between the Custom/Standard and the Deluxe.
Go to Harleys website and "compare specs" on the Custom or Standard to the Deluxe.
Write down what you've learned after you compair specs..then go to your dealer and sit on them. Test ride them. Rent each for a day if you can.
