12V plug install question....
Old Aug 9, 2012 | 07:10 AM
Swing1177's Avatar
Swing1177
6th Gear
Default 12V plug install question....
I want to install a 12V plug on my 2008 XBones. Is there someplace I can wire it to that doesn't require hardwiring straight to the battery?
Old Aug 9, 2012 | 07:59 AM
Lyttuch's Avatar
Lyttuch
They make ones that plug into your battery tender pigtail. Like this one...and there are plenty more out there...
Amazon Amazon
Old Aug 9, 2012 | 10:10 AM
JRL1164's Avatar
JRL1164
O'Reillys sells one for like $6 in the trailer section that plugs into your battery tender. Thats what I use and just put it in my saddle bag so what ever I have plugged into it stays dry in case of rain.
Old Aug 9, 2012 | 01:55 PM
Gman in NC's Avatar
Gman in NC
That's what I did. Just made one that plugs into the tender lead. I just put it into my saddlebag and charge my phone in there. Works great.
Old Aug 9, 2012 | 03:21 PM
CaptJIM's Avatar
CaptJIM
Same here...just picked one up on Amazon for $5.80. I already had a 12V USB adapter that came with my daughters I-Pod Touch, which plugs right into the new Amazon power outlet. I can now charge my RazrMaxx while riding. I just run it into a saddlebag or attached travel bag. Here is a link:
http://www.amazon.com/gp/product/B0041CDPQO/ref=oh_details_o00_s00_i00 http://www.amazon.com/gp/product/B0041CDPQO/ref=oh_details_o00_s00_i00
Old Aug 9, 2012 | 07:22 PM
FroggyFatBoy's Avatar
FroggyFatBoy
I've been cruising up the road lately and have been wondering where to mount a cig lighter on my 07 FB..
Old Aug 9, 2012 | 08:35 PM
jefkat2's Avatar
jefkat2
Get a Electrical Connection Update Kit from your HD dealer. Plugs in under the seat and has butt splices to connect your wires. They run about $16.00.
Old Aug 10, 2012 | 03:13 AM
caaraa's Avatar
caaraa
Old Aug 11, 2012 | 04:47 AM
Swing1177's Avatar
Swing1177
6th Gear
thanks for the responses guys. I actually had seen a double port one when i was wandering through the store and bought it. I never thought about the tender lead, but I did end up mounting under the spring seat, used rubber grommets to keep a tight seal around the holes I drilled for the wires and just gave myself enough wire to move the seat pan without disconnecting it, I may just have to go find the plug itself for the lead later. That would be so much easier than having to disconnect the battery every time I need to do anything that requires removing the seat pan completely.
09IronRider
Milwaukee Eight (M8)
Oct 22, 2017 09:42 PM
kjr2492
Aug 30, 2011 11:10 AM
J2X
Dec 6, 2008 01:51 PM
brackers
Mar 17, 2008 12:49 PM
dr_trousers
Aug 19, 2007 10:27 AM
