Handlebar Advice
Old Aug 10, 2012 | 10:56 AM
Sy101's Avatar
Sy101
Default Handlebar Advice
Getting ready to sit down and order my stuff..2011 Fatboy:
16" Carlini Apes
Burly Brand Cable set for the 16's
Chrome and rubber grips (to match my pedals and pads)
What am I missing? Anything anyone else would recommend I add before I drop about $700 on parts?
Old Aug 10, 2012 | 11:01 AM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Missing:
1. Poly bushings for your riser bolts
2. Wire extensions (unless that's included in your cable set)
Old Aug 10, 2012 | 11:05 AM
HoggyMtnBreakdown
Also, are your new apes 1.25 inches at the riser? If not, you're gonna need new risers.
Old Aug 10, 2012 | 11:51 AM
Sy101's Avatar
Sy101
The bars on the 2011 are 1.5, and I am ordering the 1.5's from Carlini so I am pretty sure that stock risers will fit..if I am not replacing the risers, will I still need the bushings?
Old Aug 10, 2012 | 12:12 PM
Rok n Roll's Avatar
Rok n Roll
I got the 17" Carlini Pist Apes and i am using my stock risers and bushings on my heritage
Old Aug 10, 2012 | 04:09 PM
Hondo12's Avatar
Hondo12
6th Gear
The stock bars on my 2011 Fatboy are 1.25", I had to replace the risers to install my
1.5" Carlinis ....
Old Aug 10, 2012 | 04:12 PM
wyndnface's Avatar
wyndnface
Missing riding time!!
Old Aug 10, 2012 | 07:45 PM
HoggyMtnBreakdown
If the stock handlebars are indeed 1.5 and the Carlinis are 1.5 at the riser, the stock risers should fit, but I would use poly bushings or your steering will feel really loose and mushy with those apes riding on the stock rubber bushings.
Old Aug 10, 2012 | 09:29 PM
rockinred's Avatar
rockinred
Carlini 1.5 bars are not stepped for risers. It depends on what the bars had and who made them on the previous manufacturer. Just check the risers and see if the bars are stepped down under those. If they are not stepped then they will fit. If they are you will have to get some new risers for the 1.5 width bar with no step.
Old Aug 11, 2012 | 05:42 AM
ivel_86's Avatar
ivel_86
I have a question because I am about to pull the trigger on the same apes. Everyone says that Carlini is about an inch or so higher than what the website says. Will the Burly Brand extensions work?
