Deluxe Starter Removal and Replacement
I thought I'd replace the starter in my '07 Deluxe by myself and ran into a problem that my non-Harley manual doesn't mention. I disassembled the bike to the point where I could finally access the starter and removed the 2 bolts and the solenoid wire but there seems to be something holding it from behind in the primary case. I see that there's a groove on the replacement starter on the nose section near the gear so I'm sure that's what I need to get at.
Anyone here know what I need to do? Do I have to take the whole primary case off to get at it? What was Harley thinking??
I was hoping to get it all back together for a big event in Vermont this coming weekend.
Thanks again,
Phil
Thanks again,
Phil
Thanks for the response DDeuce. I went back to the bike and gave it another try. It turns out that it was just stuck on an O-ring. That's what the groove I spoke of on the starter is for. I gave it a harder yank and it came out.
I had to tear a good chunk of the bike apart to get at the starter. Bigger job than I thought. The whole exhaust, the oil tank, fender extension to get at the tank.
Wish I didn't take the primary cover off. It's the second time this season that new fluid is going in there. LOL And I wish I had a nice exhaust to go back on it since I have it off. Oh well, live and learn.
Thanks again.
Phil
Thanks again.
Phil
Good to here, should be ready for the event. I put the factory FXST duals on mine so I only have to pull one pipe to mess with anything back there, change tire etc. Got them at a low cost off eBay, like new. No shoe melt by the passenger peg either. Didn't care for the shotgun pipes.
I ended up installing this starter off of Ebay,
http://www.ebay.com/itm/STARTER-MOTO...06%26rk%3D1%26
I noticed an immediate improvement on how the engine turned over with this unit compared to the original. The only thing I didn't keep was a breather on the solenoid. I took it off and sealed it with permatex. The original had no breather hole and I was afraid of moisture getting in it.
I just hope it lasts as long as I own the bike.
Hoosier bird
11
Feb 22, 2014 12:33 PM
