installing shotgun
Old Sep 6, 2012 | 04:06 PM
el_james's Avatar
el_james
Default installing shotgun
after a month waiting my shotguns finally arived (damn belgium customs) . now i got the compressor installed and been working on the cables . i didn't use the bracket for the switches but installed them on my tank console wich went smooth .
i just got 1 problem , i got some sort of relay (picture) i think wich i don't know where to put it . so my question is where did you put the damn thing?
put in a pic of my switches
Old Sep 6, 2012 | 05:11 PM
prldrm's Avatar
prldrm
I used that hole that's in that relay and mounted it using an allen bolt that's accessible with the mud guard off. It's hard to explain, but it's kind of high up inside the fender, pretty much the opposite side of the fender of what you took a pic of. I guess it'll be kind of a pain to get to if there's a fuse in that relay though.
DO NOT TWIST :0P
Old Sep 6, 2012 | 05:13 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Zip tied it behind the splash guard.
Old Sep 6, 2012 | 07:22 PM
Snowyone's Avatar
Snowyone
I screwed it to the splash guard to.
Old Sep 6, 2012 | 08:37 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Old Sep 7, 2012 | 01:07 AM
el_james's Avatar
el_james
ok thx . gonna check it out .
Old Sep 7, 2012 | 01:34 PM
el_james's Avatar
el_james
ok i got a few other questions . when i mount the shocks is it normal that with the stock bolts i can't tighten to the end ; the washer still is lose (picture) .
should i fill this up or not ?
also i want to know how long the airline is suppose to be . is it possible that it's not even 2cm (a bit less then 1")?
Old Sep 7, 2012 | 04:26 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Normal. Do not fill the space up.
Old Sep 7, 2012 | 04:42 PM
purpledeuce's Avatar
purpledeuce
Leave enough slack in the air line to drop the shocks to drain the tranny
Old Sep 7, 2012 | 07:50 PM
Rokkerhead's Avatar
Rokkerhead
The shoulder bolts act as an axle. The bolts won't tighten all the way to the eyelets. It's to allow for movement.
I didn't cut the airline at all. Just make sure there is no interference.
