Help diagnosing problem
Old Sep 23, 2012 | 02:59 PM
stan928's Avatar
stan928
Default Help diagnosing problem
Wife & I broke down yesterday. We had ridden about 180 miles on 02 Heritage. We were coming up a hill outside of Laughllin, NV. While climbing hill engine started sputtering and cutting out, sounded like it was missing on a cyl. The bike would start again but ran really rough, still sounded as if it was missing. It was really hot, about 108'. I seen posts about the temp sensor? Maybe it got too hot?
Plenty of gas I had just filled up with Chevron 91 octane.
I've replaced the battery, cleaned terminals and still have same problem.
All fuses are fine.
I'm thinking the problem is electrical or maybe bad fuel? Any ideas?
Thanks for any help!
Old Sep 23, 2012 | 03:15 PM
SJ58's Avatar
SJ58
How do the spark plugs look?
soft 02's Avatar
soft 02
Have you checked for any codes?
Old Sep 23, 2012 | 03:36 PM
stan928's Avatar
stan928
Plugs looked ok. A little dark but not too bad. Cleaned them and replaced.
I'm searching now for how to get/read codes.
Thanks.
Old Sep 23, 2012 | 03:39 PM
soft 02's Avatar
soft 02
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing
speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting
sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should
illuminate. The word “diag†should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with
the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing
is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back
to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button
in for 5 seconds and release. If there are any DTC’s the code will be
displayed or the word “none†will appear if there are no DTC’s. Push the odometer reset
button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part
number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in
and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it
down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control E
__________________
Old Sep 23, 2012 | 04:21 PM
stan928's Avatar
stan928
Soft 02,
Thanks. I'm trying this but not seeing what you say I should.
Ign: Off
Run switch to run.
Depressing spedo reset button (left side of speedo about even with the bottom glass)
While depressing speedo reset turning ign switch clockwise to Ingnition. Release reset button.
Here'e what I get:
do1CLr (pressing reset runs the 1 up to 10)
after if get to do10CLr pushing reset shows: PPU
pushing reset agin: 82822
reset again: back to do1CLr
Nothing flashes....
Old Sep 25, 2012 | 05:14 PM
stan928's Avatar
stan928
Any help here?
I take it that do1CLr means clear or no error.
I have a fully charged battery and have changed the plugs. Bike will start but runs really rough like it has jumped timing and backfires the dies after a few seconds or when you blip throttle.
I picked up a multi test meter and I'm going to test the VR tonight. But not starting with a fully charged battery is causing me to think the problem may not be electrical but something to do with fuel?
Any help would be appreciated.
Old Sep 25, 2012 | 06:00 PM
FroggyFatBoy's Avatar
FroggyFatBoy
if it started right after fueling up, i would suspect a fuel problem. maybe it had more ethanol then advertised..
long story short as possible....
by coincedence i had a vehicle in the shop today with a check eng light on, poor power, slow acceleration etc.. the fault codes were for lean condition. everything checked out sensor and eng wise. i had the writer call the customer and they had just fueled up 3 days ago.. i did a fuel / alcohol test with this neat little test tube tool we have and it was 35%.. max should 5-10 % unless you have a E85 capable vehicle.
i would drain the fuel and put in known good gas and see what happens.
Old Sep 25, 2012 | 06:21 PM
quasar's Avatar
quasar
So, what was it ? had a similar problem which wound up being the master circuit breaker...
Old Sep 25, 2012 | 07:10 PM
Dixie Dreg's Avatar
Dixie Dreg
Just filled up? The problem might be the gas,I would try a cam of Seafoam and change the plugs.
