The pipes should fit but you won't have a place for your O2 sensors. Your sensors should be 12mm. I think these are your choices:
Get pipes made between '08 to '11. They will have 18mm O2 sensor bungs and you can use an adapter.
Get new pipes made for '12 and later models which have a 12mm O2 sensor bung.
Get older pipes (1986-2007) like the ones you are looking at and install 12mm O2 bungs. This seems like the most work to me so the deal on the pipes would have to be good.
I believe this information is correct- someone else can chime in if I missed something.
