How do you lube the swingarm on your softail and with what? Went on a wild goose chase down a dirt logging road through some bad advice. Washed the Fat Boy as soon I was home. Now the rear squeaks like an old rusty bed.
Appreciate if i get pointed to the right thread if there is one.
Thanks Octo & NiteTrain. I just logged to see what was said before heading to the store. No grease Zert is good to know, I was looking. It's got an Air ride set up. Brand not known. I laid on the ground and raised and lowered it a few times and it sounds like it's just the shock pivot points. And no pressure washing. Dully noted.
no problem. I try to go out of my way to avoid dirt roads, buts thats only because belts are expensive and they don't appreciate rocks being stuck between them and the pulley
This has happened on several of my past Harleys and it turned out to be dust and dirt on the drive belt. My local dealer suggested I wash the belts with warm soapy water. Thie resolved the squeeking issue.
