which swingarm bag?
Old Jan 11, 2013 | 03:36 PM
fren5's Avatar
fren5
Default which swingarm bag?
looking to add a swingarm bag to my deluxe and to just use use my leatherpros saddlebags and tourpack when i tour,(not often enough), have seen all the posts here but didn't notice any boss bag pics, a little pricey but i'm sure the quality is top notch, width is 4.5 which should be ideal,anybody using this bag and if so what are your thoughts on it,thanks
Old Jan 11, 2013 | 05:15 PM
Misbehaven's Avatar
Misbehaven
All I can say is that the other two bags mentioned all the time here are both great quality bags. You can't go wrong with either. I have the 5" wide Leatherworks and love it.
Old Jan 11, 2013 | 05:39 PM
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
Leatherworks did mine too. They will customize. I did my 5'' without the straps (fastners hold it down) because I like the clean look.
Very reasonable prices and great service.
Old Jan 11, 2013 | 05:46 PM
jokr's Avatar
jokr
Garage leathers did mine great quality
Old Jan 11, 2013 | 06:24 PM
FLYING_BURRITO_BROTHER's Avatar
NOT A MODERATOR
YOu can't beat Garage Leathers for the money (not cheap and not way overpriced)....
hand made, not mass produced.
Old Jan 11, 2013 | 06:28 PM
Sgt_Jim's Avatar
Sgt_Jim
both Leatherworks and Garage Leathers are great..won't be let down with either one.
Just whichever one you get, you'll probably want to use zip-ties rather than the leather straps they come with to mount it.. and you'll want to pick up some 3M 33+ Super tape to wrap your swingarm, because both the leather straps and/or zip ties will eat right through the powdercoat on your swingarm. There's also threads on how to make your own mounting plate out of some metal plates and bolt it directly to your belt guard holes, if you do a search you can find those.
Old Jan 11, 2013 | 06:33 PM
Poolie's Avatar
Poolie
I like the look of the smooth bag but how are these bags in the wet? Do you need to use waterproof liners?
Cheers,
Old Jan 11, 2013 | 06:47 PM
Sgt_Jim's Avatar
Sgt_Jim
i never have.. no problems, even after riding after a downpour 300 miles away from home
Old Jan 11, 2013 | 07:55 PM
NOT A MODERATOR
Yep.
I used this dudes:
I basically did what others did. I used 1" coupler nuts for the forward/top and lower chain guard mounts. The rearmost chainguard mount, I used a 3/4 " spacer and a 1.5 inch bolt. This all allows the bag to sit approx 1/8th inch off the swingarm. Inside the bag is where I used plexiglass.
All hardware is 5/16 and in assembly order. (I painted all visible hardware black)
8x11 plexiglass sheet cut to fit inside bag.
Lower mount
3/4" set screw or stud (threads into chain guard/frame)
two spacer washers
1" coupler nut
Fender washer (against the bag outside)
3/4" button head bolt and a washer (inside bag)
Front mount upper
1" bolt (replaces original shorter bolt, reuse existing washer)
two spacer washers (other side of chain guard)
1" coupler nut
Rear mount upper
Begin inside bag
1.5" bolt and a washer
Fender (or smaller) washer against the bag outside)
3/4" spacer
Thread into existing hardware in chain guard.
LeatherPro
Apr 13, 2017 04:42 PM
Mikula
Jun 15, 2015 07:48 PM
STREAK
Aug 1, 2014 09:55 AM
Mr.Softy
Apr 24, 2011 11:00 PM
cdrich
Aug 26, 2009 09:22 AM
