Rotor install
Hey Guys – pretty much a new newbie when it comes to wrenching on the bike (2011 Fatboy Lo) but this forum has taught me lots and I am learning along the way. I replaced the stock front rotor with a RSD Black Ops rotor 11.5”. After installing the rotor I replaced everything as it was – axle, left/right spacers, pinch bolts and torqued everything back to spec. My problem surfaced when I went to remount the caliper. There isn't enough room to get the caliper behind the fork mount. I probably need a 1/8” just to clear the fork mounts and then I am not sure if the rotor would be centered between the pads.
I noticed once I placed the RSD rotor on the hub it didn't seat quite as low as the stock rotor so I presume that’s what’s throwing things off? With all of the brainpower on this forum (and little typing this) I am hoping someone can steer me in the right direction. Maybe a spacer issue?
You didn't mention exactly which rotor you bought, but a quick look at one (actually all) RSD 11.5" Black Ops disc says:
"RSD rotors will not work with stock HD wheels"
http://www.rolandsands.com/products/...Disc-Black-Ops
