Fatboy with problems. Help
Old Feb 28, 2013 | 06:53 PM
Devon_344's Avatar
Devon_344
Stage II
Default Fatboy with problems. Help
My dads 03 hd fatboy recently had the csps "crankshaft position sensor " go bad while on a trip so was towed to the near by hd dealer. And since then the check engine light will sometimes come on going down the road . And has started running rough. So checked the power commander and for me to get the afr down to 13.2 -13.8 I was having to put over 100 points of fuel into the programmer and the reading is still going crazy from time to time. So checked the fuel pressure and have a reading of around 50-60 psi.
Where do I go from now. Any advice is appreciated
Old Feb 28, 2013 | 07:44 PM
olongapo1's Avatar
olongapo1
Very interesting situation. I'll be watching this thread closely. I assume that since the Check Engine Light is coming on, there are fault codes stored. Retrieving these codes may be a starting point.
Old Feb 28, 2013 | 09:39 PM
QC's Avatar
QC
Welcome to the Forum from Colorado!
Here is a link to diagnostic codes that I hope helps:
https://www.hdforums.com/forum/softa...odes-dtcs.html
Also check throttle position sensor.
Old Feb 28, 2013 | 11:16 PM
Devon_344's Avatar
Devon_344
Stage II
I watched the tps while I was monitoring the power band and wideband. And the the sensor is nice and steady .
I will try the diagnostic Tom hopefully. Thanks
Bop49
Aug 26, 2014 01:38 PM
smbwn
Apr 28, 2013 08:06 PM
RedNose44
Jan 2, 2012 11:39 PM
fastbagger
Mar 30, 2008 10:28 PM
bigjako
May 26, 2007 12:43 AM
