idiot lite
Old Mar 11, 2013 | 03:06 PM
wizardry68's Avatar
wizardry68
Default idiot lite
a friend i work with has an idiot lite issue. he cant find his book on his bike since he just moved. o no internet an i told him i would poke around. he has a 2012 fat boy. now he gets a idiot lite display that reads.... lo rng. also has it while bike is runing. any ideas? i told him use a piece of electricle tape to cover it but didnt like that idea! hahaha i tried
Old Mar 11, 2013 | 03:12 PM
jimsflh's Avatar
jimsflh
have him put some gas in it
Old Mar 11, 2013 | 03:13 PM
Misbehaven's Avatar
Misbehaven
Oops my bad.
Old Mar 11, 2013 | 04:03 PM
jreichart's Avatar
jreichart
Originally Posted by Misbehaven
Found this on another site.
You may have a dirty connection in your low fuel warning switch located in the gas tank.You need to find the switch that is screwed into the bottom of the gas tank and take the wiring harness loose there.Clean it and look for any bare wires or nicks or bad connections.if this still doesnt fix the issue you may need to get a new low fuel warning switch from the dealer and reinstall.The best way would be to take the tank off and invert it so gas doesnt come pouring out when you take off the switch.The tank should have one or two bolts or wingnuts at the end nearest your seat,take those out,disconnect the fuel lines and the tank should slide off.
???????? Pretty sure the instructions above are not for a Harley.....not even close.
Unless something has changed drastically since 2005, the fuel level float switch is located inside the tank along with the fuel pump assembly. The float switches are notorious for going bad. There is nothing to access via the bottom of the tank, aside from the electrical connector for the fuel level gauge. Everything in the tank is accessed from the top, below the dash is the access cover. You can remove everything from the acess cover without removing the tank. Watch a youtube vid before attempting, as this process is a huge PITA if you have never seen it done. If you need to remove the tank, it will be easiest to drain it when you cut the crossover line. I would not leave it full and invert it, that makes no sense at all and does nothing for you as there is nothing to access from the bottom of the tank. I am also pretty sure there are no models with wingnuts holding the tank on.
Can't help too much on the "lo rng", but sounds like either low fuel, or bad float.
AnejoKid
Aug 27, 2013 09:35 AM
silent bob
Dec 20, 2012 08:36 AM
jkwbrown
Apr 15, 2010 08:47 PM
SalsaNChips
Jul 29, 2009 04:40 PM
bogie
Feb 28, 2007 11:15 PM
