Two part question.
Old Mar 16, 2013 | 10:41 AM
Dark lo's Avatar
Dark lo
Default Two part question.
I just removed the stock seats and put a Brawler Solo seat.
How do I remove this plastic? I imagine it will leave a glue type film once its removed, what do I use to clean it? Any suggestions will be appreciated.
Old Mar 16, 2013 | 10:50 AM
QC's Avatar
QC
Peel it off and then Googone or Goofoff. Might help if you heat it gently.
Old Mar 16, 2013 | 10:55 AM
Dark lo's Avatar
Dark lo
ok. is that the name of it? GOOGONE or GOOFOFF?
Old Mar 16, 2013 | 11:07 AM
elfnyc's Avatar
elfnyc
Old Mar 16, 2013 | 11:16 AM
Dark lo's Avatar
Dark lo
Thank You ELFNYC..
Old Mar 16, 2013 | 03:53 PM
Roadie13's Avatar
Roadie13
Goo Gone should work fine. I've also used De-Solv-It. It's sold mostly at marine stores. Only difference between it and goo gone is it is all natural and seems to wipe off a little easier than goo gone.
Old Mar 16, 2013 | 04:08 PM
stailjim61's Avatar
stailjim61
And then replace it with something else or your paint will suffer. I use elcheapo window tint under the seats. Primitive, but its cheap and it works.
elfnyc's Avatar
elfnyc
as QC said a little heat on it will help you get it off alot easier , then goo it up
Old Mar 17, 2013 | 12:39 AM
redmosquito1's Avatar
redmosquito1
Loctite makes an adhesive remover in an aerosol can that works really good too. I like it better than either googone or goofoff.
Old Mar 17, 2013 | 12:41 AM
soft 02's Avatar
soft 02
I used a hair dryer and it came off fine.
