Is this normal???
Old Mar 28, 2013 | 01:31 PM
Dark lo's Avatar
Dark lo
Default Is this normal???
i recently upgraded to a SE Race Tuner.. I noticed that when i am going to shift to the next gear (when hitting the throttle hard) I am getting alot of back fire. I called the dealer and was informed that maybe the tuner has to be twicked.. or something may have a air leak??? WHAT!!! any feedback on why this is happening would be appreciated.
Old Mar 28, 2013 | 01:34 PM
soft 02's Avatar
soft 02
Is this after you had it dyno'd?
Old Mar 28, 2013 | 01:35 PM
jam436's Avatar
jam436
..decel popping is usually a sign of an improper tune or air leaks in the exhaust (head or muffler clamps not tight enough) - or both...
what pipes are you running? the kind of exhaust system may add to it as well...
Dark lo's Avatar
Dark lo
Dealer says no Dyno was needed
Old Mar 28, 2013 | 01:36 PM
soft 02's Avatar
soft 02
No canned map will do as good as a dyno with a SERT.
Old Mar 28, 2013 | 01:38 PM
Dark lo's Avatar
Dark lo
Im running V&H short shorts with a stage 1 air kit
Old Mar 28, 2013 | 01:47 PM
Dark lo's Avatar
Dark lo
I am planning on taking her in tomorrow, first thing in the morning. im a little lost on this Dyno, or no canned map, should i ask for one of those?
Old Mar 28, 2013 | 01:53 PM
2003Custom1200's Avatar
2003Custom1200
With the SERT. Best results r with the dyno. They can do a run and adjust. Otherwise the way they tune it is hook it up ride for 15 minutes and come back read the results and tune. So if they have no dyno they may ride or have you ride it bring it back to adjust if they do it that way. Ride it like u ride it.
Tango69's Avatar
Tango69
Cool
You have to be pretty careful while riding in short shorts.
Those V&H pipes will burn your legs.
Old Mar 28, 2013 | 02:02 PM
Uncle Chester's Avatar
Uncle Chester
If you go the dyno route you may want to do a little research on tuners in your area. I'm not saying it is the case with your dealer or all dealers but alot of the time dealers don't have the most competent tuners. The reality is that your tune will only be as good as the guy doing your tune is.
