It's been awesome. Like owning a totally different bike. Easy power through the rpms. Gets up to speed right now and stays there without drama. The motor seemed busy at higher speeds before, if that makes sense, and now is perfectly comfortable. Have to pay attention to my speedo again til I get used to it. The break-in you described is pretty much how I've been doing it. Up and down the tach with a couple blasts up to around 4000 rpm. Not staying at a constant speed. What a hoot! Freaking weather here keeps getting in the way of a good time, though.
QC Sounds Like your "Happy Happy... Happy" Scott will be finishing mine up next week. I am planning a weeks riding/ break in time, then Throttle up!!!
i hear you one the busy part at higher speeds. i think it seemed like the motor would be screaming over 80. I am sure that i am going to have to pay attention to the speedo as well its going to be something awesome to get used to the new bike. hahaha "NEW" its just going to feel that way. yeah the weather is going to be crap when i get back with it so i am going to have wait for saturday to do any riding. but after that its going to be a full 20 of just bike.
I was told this long ago. Break a bike in how you would normally ride it. If you normally cruise, then cruise for the break in period. If you run the snot out of it then break it in by running the snot out of it. People say you can't do that to a new motor. Nascar builders don't throw a new engine in it then putt around the track for a few hundred miles. They put in a new engine and run the dog snot out of it.
I like to ride both ways. You know we all get that wild hair and just want to fly everywhere we go. and other times its good to just chill ride like when riding with friends. I agree on break it in how you normally ride as well that is a good point on the nascar engines. I know when they do dyno runs they give it hell so why wouldn't it handle that most of the time right? I think that i will be fine as long as i don't switch the oil to synthetic to soon. i know i am going to be itching to do it. thanks for the advise.
I broke my engine in per "motoman" (ride it hard) and the piston rings sealed perfectly fine. I think the more important thing to do is changing the oil around 30-40 miles after you fire the engine up. Everything is going to be seating and wearing in and you have metal shavings in your oil. I changed mine at 40 miles, then again at 100 miles, then again at 500 miles, then change at the normal intervals. Each time the oil was changed a new filter was put on as well.
I broke mine in using the Moto method. Pulled the engine at 118k for other reasons and the pistons/cylinders looked good considering the miles and still had all the cross hatching on the cyl.
