New heads
Old Feb 20, 2007 | 05:45 PM
zoomie67's Avatar
zoomie67
Default New heads
My reworked heads finally arrived from GMR Performance. Now the fun part begins, tear down and reassembly. She'll be a runner when she's done. I'll keep y'all posted on the build.
Old Feb 20, 2007 | 06:52 PM
NW FXSTS's Avatar
NW FXSTS
Default RE: New heads
Any other mods besides the heads?
Old Feb 21, 2007 | 01:23 AM
purple haze's Avatar
purple haze
I bet probably could not keep up, but i'll be pedaling!!! Lead, follow, or get out of way. Let me know your spec's please.
[IMG]local://upfiles/24725/5CD66B4336794B2C894791A56447020E.jpg[/IMG]
[IMG]local://upfiles/24725/41E26C683F2F45678D7D588D55CE5B78.jpg[/IMG]
Old Feb 21, 2007 | 08:33 AM
zoomie67's Avatar
zoomie67
It's a GMR Performance, Power Pack 2 http://www.gmrperformance.com/
[*]10.5.1Forged CP pistons with rings, clips and pins inblack highlight or silver cylinders to match your current engine color[*]GMR 615/585 CAM[*]Head gaskets are included at no additional charge[*]Stage II CNC- (your existing) heads cut on 6 axis CNC[*]New guides tapered and diamond honed[*]New viton seals[*]New Ferrea 1.9 intake valve[*]New Manely 1.615 exhaustcut down to 1.575 ( that allows a 80% margin= great for flow) full radius valve job[*]Milled to CC needed for compression based on cam choice[*]New springs for up to 620 lift ( should you choose a larger cam later no need to replace springs)and set to correct seat pressure for the 37G[*]Machine and install compression release's[*]roller rockers[*]chrome moly 3/8 adjustable pushrods [/ul]
Should be good for at least 105 hp and 115 TQ, as it sits.
Per GMR there is another level of head port they can do that will make this kit do 120hp and 125 TQ. You have to run a larger throttle body though so it's a pretty high dollar investment for those 15 ponies.
tweaked02
Sep 12, 2017 05:00 AM
adm
Engine Mechanical Topics
22
Jul 26, 2016 07:20 AM
terrapin88
EVO
24
May 14, 2013 09:04 AM
HarleyReece
EVO
19
Jul 30, 2012 10:46 AM
bazam9s
Exhaust System Topics
Oct 15, 2008 07:25 AM
