Internal wired apes????
Old Feb 25, 2007 | 11:04 PM
bensonjv's Avatar
bensonjv
Default Internal wired apes????
I need a set of 12-13" apes for a Springer (4.75" knurl) that are setup to internally wire. 1" standard dia. I don't need fatty bars.
J&P has a set but they aren't internally wired. Any suggestions appreciated. Thanks.
Old Feb 25, 2007 | 11:19 PM
Coaster's Avatar
Coaster
Default RE: Internal wired apes????
Not sure what's wrong with the pre-drilled 1 1/4 inch bars but the Buffalo bars are reasonably priced and work with the 1" risers as do the chubby's. Other then that you could always just drill and intenally wire any set of bars you choose to buy yourself.
Old Feb 25, 2007 | 11:21 PM
Finalcut's Avatar
Finalcut
wildones
Can't remember the link but these bars are great Come pre-drilled for internal wireing
Old Feb 25, 2007 | 11:28 PM
bensonjv's Avatar
bensonjv
Nothing wrong with 1 1/4 I guess. I just didn't want to have to change risers.
I'll expand my search. Thanks.
Old Feb 25, 2007 | 11:34 PM
Coaster's Avatar
Coaster
ORIGINAL: bensonjv
Try Chubby's Wild Ones then! I just instsalled Chubby's and they mount with stock risers and are nice bars which are pre-drilled!
Old Feb 25, 2007 | 11:37 PM
imboden's Avatar
imboden
shoot I just drilled my own holes on my wifes shovel. Just start your mark with a center punch and then get the right size drill bit, can't remember right now maybe 3/8? then file the hole with a round file so you don't cut up your harness... then you've got it made. good luck. oh, and if you don't wanna do it yourself a custom shop will do it too.
Old Feb 26, 2007 | 01:03 AM
KY23's Avatar
KY23
You don't have to change your wires with most 1 1/4" bars. They are stepped down at the rise mount so that you don't have to. They work with your stock risers. I have the 12.5" Wild1 502 bars and they are setup for internal wiring.
Old Feb 26, 2007 | 05:07 AM
plasmadaddy's Avatar
plasmadaddy
Have a look at the Ness Apes - mine are 1" and internally wired.
I'm sure they do a set which aren't as high (mine are 18")
Old Feb 26, 2007 | 05:47 AM
hambone's Avatar
hambone
http://www.wild1inc.com/
PART # WO516
Old Feb 26, 2007 | 10:20 PM
bensonjv's Avatar
bensonjv
The wife gave me the green light on the 12.5's (W0516). Now I need cables.
