150 on a 90 softail??
Old Jun 27, 2013 | 04:21 PM
mike 09's Avatar
mike 09
Default 150 on a 90 softail??
Hi, I did try the search but couldnt find a clear answer. Does anyone know if a 150 will fit on a stock 1990 softail? (rear) My buddy just got new wheels and tires but the rear is a 150. Thanks in advance. Mike
Old Jun 27, 2013 | 04:52 PM
newoldschool's Avatar
newoldschool
I have a '90 softail. I'm running dunlop harley tires front and rear. and I have a 150 rear tire. and it does fit. but there is so little clearance between the sidewall and the drive belt you'd almost need a feeler gauge to tell there is a gap.
Old Jun 27, 2013 | 05:03 PM
mike 09's Avatar
mike 09
Thanks for the reply. I guess i should have said its an avon venom. I think we'll go for it. The worst that can happen is it wont work.Thanks again, Mike
Old Jun 27, 2013 | 05:05 PM
mike 09's Avatar
mike 09
I just noticed, welcome to the forum!
newoldschool
no problem. like I said it's crazy close but it fits
Old Jun 27, 2013 | 07:45 PM
run1fsr's Avatar
run1fsr
Please post the results. I've a 130 on my '96 Springer, and would like to go wider, but it's so close to the belt now ... hard to believe a 150 would fit on my bike.
FYI - Likely going to rub when you roll the bike backwards. The 140 on my Sporty barely fits, and does rub when I back it out of the garage.
Old Jun 27, 2013 | 08:02 PM
antichrome90's Avatar
antichrome90
The 150 tire will definitely fit. However, the rim is most likely too narrow for that tire. I've been told people run the 16x3" wheel (what I'm assuming you have) with 150mm tires, but it can get really squishy.. I'm looking into a 16x4 wheel and a 150mm tire for my '02 Train (stock is 130mm) because i have the 16x3 with Metz ME880 150mm now and its noticeably soft in turns (and its really only a 140 based on my measurements so a 150mm would be softer).
https://www.hdforums.com/forum/softa...ght-train.html
Old Jun 27, 2013 | 09:49 PM
QC's Avatar
QC
Here's a chart that I hope helps:
https://www.hdforums.com/forum/dyna-...chart-out.html
Old Jun 27, 2013 | 10:08 PM
newoldschool
thanks for the welcome. been lurking the site for awhile, when I saw this thread, I had to join and reply.
I'll try to take some pics of mine to post. and my rims are not stock as said earlier.
Old Jun 27, 2013 | 11:13 PM
DBH6601's Avatar
DBH6601
Have a 150 dunlap on my'89 fxstc, very tight clearance on the belt side, had to space out pulley 3/16th so belt would clear with 1 1/2 belt, would be much better with 1 1/8th belt, can't space it out any more as pulley will hit swing arm. A late model swing arm would help also.
