cv carb
Old Jul 16, 2013 | 03:16 PM
SoftailMike's Avatar
SoftailMike
Default cv carb
need help, I took my carb apart to clean and adjust the mixture screw. put back together and bike wont turn over, sounds like it wants to but lots of smoke coming from exhaust. also spits out alittle smoke around the carb/filter area when I pull the throttle trying to start it.thanks for your anticipated help
Old Jul 16, 2013 | 03:32 PM
SoftailMike
I also adjusted the float height a bit.
Old Jul 16, 2013 | 04:58 PM
roadkingharry's Avatar
roadkingharry
You have a service manual right ? How did the bike run before you took the carb apart?
Old Jul 16, 2013 | 05:07 PM
Harleycruiser's Avatar
Harleycruiser
You say the bike won't turn over, do you mean it won't fire?
Old Jul 16, 2013 | 08:16 PM
SoftailMike
Yes. It sounds like it wants to but it will not hold idle. I tried adjusting the mixture screw but will not stay running
Old Jul 16, 2013 | 08:19 PM
SoftailMike
Saturday night i took the bike out and it ran fine. Last night it was very humid and the bike wasnt running right so i wanted to clean the carb and adjust it.
Old Jul 16, 2013 | 08:36 PM
roadkingharry
What do you mean by "the bike wasn't running right" ? Sputtering, lack of power, idled poorly, ran like crap at low rpm's, high rpm's ?? You may have been having an electrical problem. What year bike?
Old Jul 16, 2013 | 08:58 PM
Harleycruiser
First thing I would do is make sure the carb is seated good on the manifold, some time the rubber seal gets pinched and lets air in.
Second thing I would check it the slide, make sure the rubber seal in the top of the carb is not pinched and make sure it is sealing good, this is a real easy part to not get seated right.
Old Jul 16, 2013 | 09:49 PM
SoftailMike
Come to find out it was only the idle screw. I screwed it down some and it holds idle. Once warmed up good it ran fine. also had to tweak the air mixture screw some. I Was having issues the other night though, i believe its electrical. Lots of misfires, popping noises and hesitations at WOT. Changed the spark plugs not to long ago so thats not the problem. Btw its my first harley if you couldnt tell
Old Jul 16, 2013 | 09:55 PM
SoftailMike
Thanks guys for your responses!
