Breakout Riser Discussion Thread
Old Apr 11, 2015 | 06:24 PM
  #81
marcelo_abs's Avatar
marcelo_abs
Stage III
Originally Posted by 24v
Beat ya to it sucker. :P
What kind of footpegs are these? I would like to use them on my blackline. Thank's
Old Apr 12, 2015 | 08:25 AM
  #82
24v's Avatar
24v
They are mountain bike pedals with the threads cut off. Then we cut the ends off the stock pegs and welded them onto the pedals.
DK Customs is a sponsor here and they have something similar.
http://www.dkcustomproducts.com/Outl...-Pegs_c116.htm
Old Apr 14, 2015 | 03:56 PM
  #83
mseymour3's Avatar
mseymour3
As promised here are some pictures of the Thunderbike risers and my new bars installed. They're Carlini bag drag bars. The Thunderbike risers measure 2.5" tall total whereas the stock risers are 4" tall. Excuse the dirt and dust. She's been sitting in the garage all winter.
Michael
Attached Thumbnails Breakout Riser Discussion Thread-img_2984.jpg   Breakout Riser Discussion Thread-img_2986.jpg   Breakout Riser Discussion Thread-img_0406.jpg   Breakout Riser Discussion Thread-img_8963.jpg
Old Apr 14, 2015 | 05:28 PM
  #84
24v's Avatar
24v
I'm not usually a fan of bars other than apes on Breakouts, but those look nice.
Old Apr 14, 2015 | 10:09 PM
  #85
mseymour3's Avatar
mseymour3
Yeah I like apes but wanted to try and keep the lower profile look similar to stock. This was the best option I could find while still providing good pullback. I've barely had a chance to test them but so far I love it.
Michael
Old Apr 21, 2015 | 04:19 AM
  #86
wavesnwheels's Avatar
wavesnwheels
Michael
Nice choice, good to see some different bars on the breakout. Any pics showing the whole bike with em on?
Old May 4, 2015 | 10:32 AM
  #87
mseymour3's Avatar
mseymour3
I have a few. I'll try to put up a couple different angles and sides.
Oh and even though the cables fit and I have enough slack it's no extra on the brake, throttle, and idle cables. Thought it was still going to work but after riding a bit more I found the front brake cable was rubbing the tank a bit. I fixed it for now but will end up getting extended cables just to provide plenty and keep them away from the tank. Clutch has plenty still and will not need changed.
Michael
Attached Thumbnails Breakout Riser Discussion Thread-img_8328.jpg   Breakout Riser Discussion Thread-img_2823.jpg   Breakout Riser Discussion Thread-img_8743.jpg   Breakout Riser Discussion Thread-img_3726.jpg   Breakout Riser Discussion Thread-img_5921.jpg
Old May 9, 2015 | 01:17 PM
  #88
jtaliani's Avatar
jtaliani
Can anyone confirm if the diameter of the Breakout and CVO Breakout risers is different? I picked up some riser extensions and they measure 1.75". However, the opening on my triple trees is only 1.5". Accordingly, my risers and the washers are even smaller. I'm trying to determine if I was sent the wrong set or if they are supposed to be different.
Old May 9, 2015 | 02:52 PM
  #89
cdonis's Avatar
cdonis
1.75 × 1.75 is what I made for my bike.
Old May 9, 2015 | 04:49 PM
  #90
jtaliani's Avatar
jtaliani
Darn, looks like these are correct then. Thanks for the confirmation.
For those that switched from regular Breakout risers to CVO risers, did you just have a gap in your trees? I guess you can't put the regular risers on the CVO, which was going to be the other direction I tried. This would actually be ideal if they fit and I could use the top part of my CVO clamp and speedo casing.
