5th Gear Slips!???
Old Aug 8, 2013 | 08:19 PM
stubb21's Avatar
stubb21
Default 5th Gear Slips!???
So I have a 12 Softail Slim with 4k miles and have been thinking that 5th Gear(only 5th) slips when I give it about 1/3 WOT. I notice that the engine speed/sound doesnt seem to match the acceleration speed.
Everyone kept telling me I was crazy, however I didnt believe them. Today happened to have the "Gear/RPM" display up on my stock console, and when I got on the throttle I noticed the "5" gear indicator disappear just like when you pull in the clutch. When I saw this I let off the throttle and noticed very briefly a "4" show up and then back to "5". Proving that A) I'm not crazy, at least regarding this and B) Something is slipping.
Anyone seen or heard of this?? I have changed both tranny covers and primary cover to black, replaced oil to OEM specs however don't recall if the problem was occurring prior.
Any help or insight is much appreciated. I have an appointment scheduled at the dealer next week however if there is something I can do or check on myself I would rather not be without it for a week.
Thanks in advance!
Old Aug 8, 2013 | 08:39 PM
jsimmons6703's Avatar
jsimmons6703
Same thing happened to me after the dealer did my 1000 mile service.. Turns out they over tightened the clutch cable.. I lossened it a little and it stopped.. 12 Heritage.
Old Aug 8, 2013 | 08:46 PM
ynots's Avatar
ynots
starting in 1st run ***** out thru all the gears, if its slipping you will know it. at 4k Id go ahead and adjust the clutch at the basket and cable
Old Aug 8, 2013 | 08:52 PM
r0de_runr's Avatar
r0de_runr
What are you running for oil in the Primary? Car oils or low friction oils will cause that, as well as a mis-adjusted clutch.
Old Aug 8, 2013 | 08:58 PM
stubb21's Avatar
stubb21
It's the stock oil the dealer told me to use
As far as getting on it starting in first, I have done that and notice no slippage except 5th. Which makes me think its not the clutch?? But hell I'm not sure.
As for clutch adjustment, it seems fine in other gears......Is it still possible that its that?
Old Aug 8, 2013 | 08:59 PM
stubb21's Avatar
stubb21
Was it only in a particular gear or all gears?
Old Aug 8, 2013 | 09:16 PM
Blk and Chrome's Avatar
Blk and Chrome
if it's slipping then the rpm will go up without an increase in speed. If it does it in 5th then it should do it in 6th too. try readjusting the clutch again first.
Old Aug 8, 2013 | 09:30 PM
Falcon195's Avatar
Falcon195
Sounds like you have too little freeplay in your clutch cable.
The reason it slips in 5th with too little freeplay is because 5th gear is a helicut gear and when you accelerate in 5th the two helicut gears push against each other because of the angle they are cut. This causes a slight amount of lateral movement to the main transmission shaft and this can cause the clutch to disengage slightly if you have no freeplay in the clutch cable.
Assuming the freeplay is adjusted correctly at the clutch hub adjustment you need to make sure you also have some freeplay at the clutch cable and lever.
Try this, in 5th gear accelerate WOT and at the same time see if you clutch lever has some freeplay. If not what I have described is probably your problem. Your manual will describe how to adjust cable/lever freeplay properly.
Old Aug 8, 2013 | 09:54 PM
stubb21's Avatar
stubb21
Awesome info man I greatly appreciate it! I will work on this tomorrow and see what happens. If this does fix it, has there been any permanent damage done? Any oil that has been tarnished?
Thanks again!
Old Aug 9, 2013 | 12:39 AM
jsimmons6703
Just 5th.. It was strange but that's what fixed it..
