What is this?
Old Aug 18, 2013 | 05:59 PM
BigMESA's Avatar
BigMESA
Default What is this?
I was looking at my brothers 03 Fatboy today and noticed these rubber capped things next top the spark plugs. What are they and what are they for? I don't think they are on my 06 NT. Thanks!
Old Aug 18, 2013 | 06:03 PM
Sgt_Jim's Avatar
Sgt_Jim
compression releases, you should have seen one on both heads.. it means someone may have had the heads bored/ported/polished.. just push each of them down before he starts the bike, and the compression from the piston firing will pop them back up. they take the stress off from the starter having to crank the motor over on big bore engines.
Old Aug 18, 2013 | 06:05 PM
BigMESA's Avatar
BigMESA
Well that's cool. They seem to spin like a cap, I don't know if they free spin or the spin off or if it's an adjustment or not. So just push them all the way in before each time he cranks it or just when it's cold?
Now that I know I don't have them on my NT...... I want them!
Old Aug 18, 2013 | 06:12 PM
QC's Avatar
QC
Specially when hot. No adjustment needed. If they ever stick open, take them out and clean them.
When you do your big bore kit, then do them.
Old Aug 18, 2013 | 08:07 PM
back again's Avatar
back again
They are needed in high compression motors especially 10 to 1 and higher. I never needed them when I just had the 95ci motor that came in just under 10 to 1. When you jump up to 10.5 and higher a hot motor benifits from them and a good starter. I say they aren't needed in a lower comp.motor but if you have them use them. You will know the first time you crank it over when hot. I never use them starting my motor cold.
Old Aug 27, 2013 | 06:51 AM
VETERAN75's Avatar
VETERAN75
Mesa they are compression releases. Push in before every start is best. Careful not to burn fingers when engine is hot. They are a pain if you're bar hopping with frequent starts. The button on top will spin either way, it's just a shaft with a plunger on the bottom inside the head. Eventually they will start to stick open. Take them out, wipe off any dirt, lubricate the moving parts with a light coat of engine oil, put back in. Careful not to overtighten putting back in. The threads are small and the head is aluminum.
Old Aug 27, 2013 | 08:10 AM
rockinred's Avatar
rockinred
Looks like a great discovery since he didn't do it himself.
Old Aug 27, 2013 | 08:16 AM
BassCatcher's Avatar
BassCatcher
Every chain saw I own has a compression release but I have to admit I have never seen one on a bike.
Old Aug 27, 2013 | 03:43 PM
VETERAN75's Avatar
VETERAN75
Also, since the 03 came with a 88" it's probably now a 95", could be a 98" but most likely a 95" build. I would start some back tracking to see what I have gotten for future reference.
Old Aug 27, 2013 | 05:02 PM
BigMESA's Avatar
BigMESA
Thx guys. Yea after talking to the previous owner it's a 95" now.
He's loving the pipes btw Veteran75
