How to?
Old Aug 30, 2013 | 11:36 AM
tbonetony06's Avatar
tbonetony06
Default How to?
I have a simple question. I have often seen on here where someone has asked a question and they are told that there has been many threads on that subject, to go back and research it. How does one do that? How do you find a spacific thread on a spacific topic on an old thread? Sorry, PC illiterate here. Thanks to whoever takes the time to answer.
Old Aug 30, 2013 | 11:38 AM
ynots's Avatar
ynots
I find that "googling" something comes up with better results, even for treads/posts on this site
Old Aug 30, 2013 | 11:43 AM
Redbeard719's Avatar
Redbeard719
Meh, it's hit or miss.
I usually select the search feature at the top of the page, and then choose advanced search.
If you enter in multiple words like Carlini Risers, it will result in threads that have Carlini and threads that have Risers. If you put the term in quotes, it will match the specific phrase, ie threads with "Carlini Risers".
I also only select the forums I want to see results from. If looking for a Softail issue, I don't care about all the threads from the Touring section. Under the advanced search, you can choose the specific forum. If you want to search more than one forum, make your first selection, then hold down the 'control' key for every addtional selection you wish to make.
Aside from that, searches with very specific terms are less fruitful. Vague searches cast a wider net, but require some sifting.
When all else fails, just post a new topic. One thing you've probably noticed, this forum is cyclical. We're heading towards winter, so get ready for all the cams/apehanger/exhaust threads to start popping up again.
Edit - if you want to use Google to search the forums, you can.
Say you want to find threads about Carlini Risers.
Go to Google -
Enter the following, minus the quotes "site:hdforums.com carlini risers"
Old Aug 30, 2013 | 11:44 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
There's two "search" boxes above your post. One's in the blue bar and one is above that. There's also one to the right of your post but it's for searching this thread.
Some searches either turn up too much stuff and not the right thing, which makes searching a pain, so people ask. And you'll always have those that'll say search it and be a dick about it. I usually point them in the right direction with a link and where I found it.
Old Aug 30, 2013 | 11:49 AM
Bluraven's Avatar
Bluraven
I agree with "ynots", however to search only this site; in the upper right above the existing Threads is "Search this Forum".
If you select the drop down arrow it opens up a window where you can type a key word or phrase such as "oil change".
This will only search the Softail forum.
If you want expand your search to all forums, from the drop down window select "Advanced Search" and then under "Search in Forum (s)" select "Search all Open Forums"
Good luck
Old Aug 30, 2013 | 12:31 PM
ynots's Avatar
ynots
Thanks for the tips! I have thought about starting a tread for the same subject. There is nothing Elite" about me lol
Old Aug 30, 2013 | 01:03 PM
tbonetony06
Thanks.
Old Aug 30, 2013 | 01:10 PM
HDogg's Avatar
HDogg
It ain't exactly the most user friendly site but once you get the hang of it,you'd be fine...I'm still fumbling
Old Aug 30, 2013 | 01:12 PM
47909Rider's Avatar
47909Rider
It's standard on most forums for people to just say "meh, use search."
I disagree with that advice - usually. The problem is there are numerous ways people might choose to word things, while computers are 100% literal, and so if you search for "heritage footboards" for example, you're not going to find the threads where people called them "heritage floorboards." Not to mention people often misspell things.
Old Aug 30, 2013 | 01:18 PM
HDogg's Avatar
HDogg
Agreed.In any case I think the community here is pretty friendly and if you ask,most likely you're directed there.
