Night Train won't start!
Old Sep 28, 2013 | 01:40 PM
skidve007's Avatar
skidve007
5th Gear
Default Night Train won't start!
I have an 02 night train that I accidentally tipped over on it's side and now it won't start. Does anyone know what would be preventing it from starting?
Old Sep 28, 2013 | 01:53 PM
agapsdiver's Avatar
agapsdiver
There is a lean over cutout. you need to recycle the main switch I believe by turning it several times from Off, to Access,to On, and back again. Do this a couple of times. this resets the ignition, I think. Sorry I don't have my manual handy, but I'm sure someone else will know.. in the mean time try my suggestion.
Old Sep 29, 2013 | 02:39 PM
skidve007's Avatar
skidve007
5th Gear
Thanks agapsdiver. I found some instruction in my service manual. It's called the Bank Angle Sensor. It told me to do exactly what you said to do. I'll let you know if it works.
Old Sep 30, 2013 | 05:39 PM
agapsdiver's Avatar
agapsdiver
Hmmmmm... no wonder I couldn't find it again in my manual..
"Bank ..." why didn't they name it Tip-Over or Lean-Over sensor, then I could have found it.
Old Sep 30, 2013 | 08:05 PM
skidve007's Avatar
skidve007
5th Gear
Well I tried cycling the "On" "Off" switch and it didn't work. Any other ideas?
Old Sep 30, 2013 | 08:18 PM
Jackie Paper's Avatar
Jackie Paper
Is it cranking? If running and it drops, just turning key off and back on resets it. If the key was off, it would not matter. It's in the turn signal or alarm/turn signal and it kills the fuel pump on an FI bike. Does the turn signal light work? What is your voltage reading on the battery lead terminals and on the metal wires eyes hooked to the battery?
Old Sep 30, 2013 | 10:01 PM
agapsdiver's Avatar
agapsdiver
Give us answers to these questions.
Old Oct 1, 2013 | 08:12 PM
skidve007's Avatar
skidve007
5th Gear
Ripsaw message "Is it cranking? If running and it drops, just turning key off and back on resets it. If the key was off, it would not matter. It's in the turn signal or alarm/turn signal and it kills the fuel pump on an FI bike. Does the turn signal light work? What is your voltage reading on the battery lead terminals and on the metal wires eyes hooked to the battery?"
Nope my bike won't crank over. Both turn signals work just fine. It wasn't running when it tipped over. I'll need to borrow a meter to check voltage.
Old Oct 2, 2013 | 04:57 AM
Jackie Paper
Flip the bar switch to run.
Old Oct 2, 2013 | 06:35 AM
08Nighttrain's Avatar
08Nighttrain
Was anything at all damaged when it feel over? Clutch, shifter any wiring? Is battery leaking are connections tight? Is the battery full charge? Any fuses blown? You need to start from scratch and start going through checklist things that it could be. Maybe battery died coincidentally and your over looking it or something along that line.
