Heritage Headlight Issue
When dose the speedo blank out, is it when the head light gets brighter or when it gets dim?
If it's when it gets dim, follow the wires back to the main fuse and battery,also test the voltage regulator and stator.
If it's when it gets brighter (real bright or normal bright?) test the voltage regulator and stator.
I went ahead and reinstalled the harness that allows the spot lights to stay on while the high beam are in use and didn't have any problems with the head light. Coincidence... maybe... I think I'll remove the headlight again and check all the wires to make sure everything looks ok... I appreciate all the help...
Humm Maybe the 2012's I went to the Harley site put in my VIN and nothing showed up...
Speaking of which, I don't remember if it was actually a "Recall" or one of those "Product Program" listings.
I think it was the latter for a Dyna I had last year.
For an official "Recall" they'll notify you, for a "Product Program" announcement, they won't...
Dynas as well...
I've heard on more than one occasion that maybe the recall didn't go far enough, as there were plenty of bad regulators out there that fell outside the range of official listed recall numbers...
Digindeep
Electrical/Lighting/Alarm
Aug 2, 2017 12:02 PM
