Dim headlight
Old Aug 9, 2008 | 11:09 AM
rcc's Avatar
rcc
Default Dim headlight
I posted this in the electrical forum with no response. I have an 05 Heritage. The headlight is really dim, I have to use the running lights to see at all at night. I've noticed other bikes were the same way.
I see where people are putting higher wattage bulbs and heavier wire so it doesn't melt. What is the best way to go? Is it really designed to be that dim? it just kind of casts a shadow in front bike about 20-25 ft.
Thanks, Ron
Old Aug 9, 2008 | 11:21 AM
White-Trash's Avatar
White-Trash
It shouldn't be dim. Maybe a ground wire loose. Usually when the bulb goes out, it goes out without warning.
Old Aug 9, 2008 | 11:28 AM
ngoti8tor's Avatar
ngoti8tor
Are your running lights as bright as they should be? If so, I would think it's something like a bad connection to the headlight.
If the running lights are also dim, I think you may have a problem with either your battery or your charging system.
Old Aug 9, 2008 | 11:51 AM
rcc's Avatar
rcc
Running lights are bright. High beam is bright. Charging system seems to be O.K. Maybe just a bad bulb, but they usually just go out.
Old Aug 9, 2008 | 12:41 PM
ngoti8tor's Avatar
ngoti8tor
Sounds like a bad bulb. It's worth a try. Worst that can happen is that you end up with a spare bulb.
Old Aug 9, 2008 | 01:38 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Answer HID
Just throw HID in it & be done.
Old Aug 9, 2008 | 01:44 PM
Bluesssman's Avatar
Bluesssman
Bulbs don't go dim, they either work or they don't. I would check your ground wire for good connections, then check the plug to the lamp connection. You may find some corrosion has developed. Hope this helps...
Old Aug 9, 2008 | 04:30 PM
Archer1968's Avatar
Archer1968
Test the socket, you should be getting around 13.6 amps. if its between 12-13.2 your stator may be week, causing the dim lights.
coylizard
Engine Mechanical Topics
Oct 16, 2020 09:05 PM
City Worker
Mar 20, 2018 05:32 AM
harley-jones
Mar 5, 2009 05:10 PM
rcc
Aug 7, 2008 11:31 AM
bdwjdw
Dec 6, 2005 11:00 PM
